Akata Spacer guys - torque question
To those that have Akata Spacers, what are you torquing the spacers down to on the hub? And also the lug nuts down to when installing the wheel? My local shop installed them when I had new tires put on and I'm getting vibration at speeds over ~70mph.
Thanks!
Note: These are the 20mm spacers on factory 18's. Car is a 2012 Acura TL SH-AWD.
Thanks!
The Original Shawdy
Should be torqued down to factory spec or tighter. Both spacers and wheel lugs. Mine are actually torqued down to 94lbs.
The Original Shawdy
No vibration for me
Thanks!
Thanks!
