How to make this setup work?
Hey guys!
I'm in love with these Vertini Dynasty wheels! But I don't know how to get started. I have a 2013 Acura TL sh-awd, I know that my bolt patterns are 5x120 and the tire size that I want to go with is 20" but for the x"8.5,9,10.5", I don't really understand much. That is why I need help! What would be the recommended offset for an acura tl sh-awd?
These are the wheels I really want to go with! Any help and info would be awesome! Once setup is complete I will be posting photos! Thanks guys!
http://www.vertiniwheels.com/Wheels_P2%20DYNASTY.html
those are very nice looking cast wheels.
those values you posted above are the width of the wheel, so depending on how flush you want them to be against the fender, and how you want to play with your offsets, the choice is yours.
go check out the fitment thread and pay attention to how flush everyone goes, some like it in line, some don't mind a bit of sink, some even have some poke. that will give you an idea.
also check out the wheel size calculator on here, extremely helpful for playing with offsets.
This website has the offsets for the different widths. 19x8.5 et35 is going to get you pretty flush at stock height. Are you planning on lowering your car? If you do, the wheels sink in a bit so you have more room to play.
http://www.wheelplususa.com/wheels/V...sty/Slate+Gray
20x10 et38 seems like it'd poke a bit at stock height, no? Not sure if he's lowered or not, but might look weird if he's not. I was assuming he's stock height, where 20x8.5 et35 would get it right at the fenders. If he's lowered or planning on lowering than yeah.
Hey there I'm at stock height, not planning to lower it either. So would 20x8.5 et35 be a good to go?
Hey bronco, so is there a purpose to having a bigger width of a tire? Sorry i don't know any of this. Why didn't u go with standard?
as stated..
there is a difference between the two. comprende?
LOL...
1) People don't drive with just wheels, so why even post that the wheels are tucked and the tires make it flush
2) Those tires UCF posted don't bulge out much. If anything, the tires make them poke a bit (look at his leveler). The wheels themselves go flush to the fender
3) 20x10 et38 is going to poke completely, wheels alone without tires
Yeah, I might do the same for tire size due to cause winter gets nasty out here in Minnesota. So then 20x8.5 offset of 35 all around would be good to go for wheels? And for tires do the 255 series?
Also, don't forget your hub centric rings!
Let's say I go with stock size on the tire would I need to roll my rear still? Where would I buy my hub centric rings?
As potz said, you can buy the rings on ebay. However, the place I bought my wheels had them so you may want to ask. They should know the exact size you'll need too.
Also as potz said, the lower the offset the further the wheels stick out. The OEM wheels are +55.
Stock size tire (245/35/20) and you'll be fine...no fender rolling needed.
Hey bronco so would by tire choice by alright then? 245/35/20 with a 40 offset. Wheel will be 20x8.5?
Unfortunately since I live in FL I can't really comment on all season's performance in snow, but I'm running on Falken ZIEX ZE950 all seasons and they perform great in dry/wet (i.e. rainy) conditions. They also have minimal road noise and a treadwear rating of 500.
I recommend Toyo Proxes 4 Plus - all seasons.
I personally use seperate winter tires, but i've heard a few friends go on (and on...) about how good they are in the winter, so there's that.
cycdaniel
Dec 17, 2019 10:58 AM
