Washer Fluid Warning
Old May 13, 2015 | 01:28 PM
stevesin's Avatar
recently installed a hid kit for my fogs, and since then, the washer fluid warning won't go away. i've unplugged the sensor and plugged it back in.
is there anyway to fix myself or do i need to go to a dealer, or is there an option to disable the warning?
Old May 13, 2015 | 01:29 PM
add more washer fluid
if that doesn't work try removing the negative terminal of the battery and plug it back in a few minutes.
Did you make sure to use a relay for your fogs?
Old May 13, 2015 | 01:38 PM
stevesin's Avatar
i forgot to add, i topped it off the same night i installed the fogs.
if i remove the negative terminal of the battery, would i need to get the pin for the nav again?
Old May 13, 2015 | 01:39 PM
yeah. you likely will need the PIN.
did the fluid sensor unit maybe go bad.. check the service manual for troubleshooting with a multimeter to see if it maybe shorted out somehow?
Also re: question about fogs and relay, did you?
Old May 13, 2015 | 01:42 PM
stevesin's Avatar
yes, there was a relay installed.
Old May 14, 2015 | 07:35 AM
LNJ's Avatar
LNJ
What is this PIN?
Do you need one every time you unplug the battery?
Old May 14, 2015 | 11:06 PM
Edward'TLS's Avatar
6G TLX-S
Yes, every time the battery is disconnected, you will need to enter the PIN to unlock the radio and the navi.
Old May 15, 2015 | 11:35 AM
Tonyware's Avatar
'20 TLX SH-AWD A-Spec
That washer fluid sensor has gone bad on all Acura and Honda products I have owned in the past. Lots of posts in all kinds of Honda related forums out there. Unless you are prepared to spend $100 for a new one, what I would do is disconnect the connector.
Old May 16, 2015 | 10:31 AM
LNJ's Avatar
LNJ
For real?
Where would I find this pin? is it on a card somewhere with the warranty stuff? Would the dealer that sold the car have the pin in case I can't find it?
Old May 17, 2015 | 06:16 AM
stevesin's Avatar
ended up fixing this, took it to a buddy's shop, they pulled the sensor, cleaned it out and plugged it back in. drained my fluid as well, and refilled it. no issues since
Old May 17, 2015 | 08:25 AM
NBP04TL4ME's Avatar
Stay Out Of the Left Lane
Originally Posted by LNJ
For real?
Yes for real.
Yes you should have a card with your paperwork
Yes the dealer that originally sold the car will have both the PINs for the radio and nav.
SidhuSaaB
May 30, 2020 12:40 AM
LeVeL
Oct 18, 2015 04:19 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
Cexarin
Sep 23, 2015 07:43 PM
ROSSARONIE
Sep 22, 2015 11:46 AM
