TPMS Valve Leak - Help Please!
Old May 12, 2014 | 11:12 PM
wmahmud's Avatar
My 2009 Acura TL FWD with 110,000KM has the rear passenger side TPMS valve leaking air slightly and over about 3 weeks time the tire pressure will drop significantly (have filled it 3 times to watch it come down, and a body shop yesterday sprayed some soapy solution on it and it was bubbling).
Question is,
1; what exactly do I need here? a full TMPS including a nut and washer, or just a valve, or what?
2; I am in Toronto, Canada - whats my best option, should I buy new? used? what website? dealer? etc.
I saw this guy locally having one, should I go for this? Is this even the correct part?
http://www.kijiji.ca/v-tires-rims/ci...ationFlag=true
Any help would be great please so I can get this sorted out with a smallest cost possible
Old May 12, 2014 | 11:15 PM
wmahmud's Avatar
Or do I only require this ? as the sensor is totally fine
http://www.ebay.ca/itm/TPMS-Sensor-S...a49122&vxp=mtr
Old May 13, 2014 | 03:21 AM
Edward'TLS's Avatar
6G TLX-S
If it is just the valve seat sealing problem, there is an OEM rebuild kit available from the dealerships.
Old May 13, 2014 | 12:19 PM
Jackieee_TL's Avatar
Try tightening the nut a little more and see if that solves the problem. If not, then get a rebuild kit like Edward suggested.
Old May 13, 2014 | 12:29 PM
there's something called a schrader valve in the tire stem.
this little tiny valve is what leaks.
tighten it or replace it.
go to a tire shop and they'll have millions of them laying around. be friendly and strike up convo with a worker and have them install it for free.
only takes like 5 sec.s
Old May 13, 2014 | 11:29 PM
wmahmud's Avatar
How do you tighten it? Do I need a special tool?
Old May 16, 2014 | 01:37 AM
dcmodels's Avatar
YES, but you can purchase the tool at any auto-parts store, or just have any tire shop do it for you.
Old Jun 6, 2014 | 10:09 AM
wmahmud's Avatar
Update; replaced the grommet, washer, and bolt 2 days ago, keeping eye on it
Mike734
Dec 10, 2021 01:25 PM
IBankMouse
Jun 13, 2020 12:53 PM
Avenger411
Oct 11, 2015 03:53 PM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
