TPMS Help
Old Oct 27, 2014 | 08:54 AM
Road-Rager 1's Avatar
TPMS Help
Had a flat repaired and my TPMS is "stuck" at 51psi. After first seeing the TPMS at 51, I let a good amount of air out of the tire, enough to release at least 8-10 psi. The TPMS still read 51psi. I went home and shut the car off for a while thinking it would reset. It didn't!
Looked in the manual how to fix/reset the TPMS - no help found.
What do I need to do? No problem going back to my mechanic but I'd rather fix it myself if I could.
Old Oct 27, 2014 | 11:47 AM
potmilkz's Avatar
jack it up so that said wheel is floating.. release the air and start the car.
wait a few mins and see if the PSI changes, if it stuck there then your TPMS is fucked up and you will need a new one.
Old Oct 27, 2014 | 12:24 PM
NBP04TL4ME's Avatar
Stay Out Of the Left Lane
What exactly did you do to get the flat repaired? Could be the shop that fixed your tired damaged your TPMS sensor.
Another option to try and diagnostically figure this out is to rotate the tire out of it's current position on your car and see if the "51" moves to a different location on your TPMS display.
Old Oct 27, 2014 | 01:12 PM
potmilkz's Avatar
moving it wont do anything, the problem is that it is readying the tpms wrong.. like i said.. deflate that shit, see if it reads low psi.
Old Oct 27, 2014 | 02:29 PM
Edward'TLS's Avatar
6G TLX-S
There is nothing to reset the TPMS sensor.
It either works or doesn't.
Old Oct 27, 2014 | 03:00 PM
NBP04TL4ME's Avatar
Theoretically if you move the "bad" wheel from its current position and put a good wheel in that position it will either read correctly or not. If it reads correctly you know the sensor that reads the TPMS is good and the TPMS sending unit in the wheel is bad. If it reads incorrectly, then the sensor is likely bad. From there you can check to see if the "bad" wheel reads correctly in a different position.
Old Oct 27, 2014 | 03:24 PM
potmilkz's Avatar
probably worth a "try"... but i wouldnt even bother trying... mechanic touched the TPMS and not the sensor.. rarely do those things go bad.. and when it goes bad, it usually just doesnt read.. it should not show 51 PSI... id bet money its on the TPMS itself since it was tampered with.
Old Oct 27, 2014 | 03:44 PM
NBP04TL4ME's Avatar
You are more than likely correct, but I always like to know as much as I can about the problem before heading to the mechanic. Less opportunity to get snowed.
Old Oct 28, 2014 | 11:17 AM
Went back to the shop and completely deflated the tire. The sensor is now working as it should. Thanx for all the help.
Old Oct 28, 2014 | 11:34 AM
NBP04TL4ME's Avatar
Glad it worked out for you.
neuronbob
23
Jul 16, 2019 10:48 AM
bailey24
Nov 21, 2015 08:43 PM
johnalfa
Nov 5, 2015 06:44 PM
johnalfa
Oct 31, 2015 12:55 PM
RobbDizzle
Oct 15, 2015 11:16 AM
