Surging Idle
Old Feb 22, 2024 | 06:54 PM
maxAmillion's Avatar
2010 WDP TL Tech
Surging Idle
I have a 2010 TL and I cleaned the throttle body today with a toothbrush and rags. (It was very black) Now when I start the car the rpms raise to about 2,000 then settle down. Also the rpms surge while driving. Any idea what it could be? BTW throttle body was still attached and car was off
Old Feb 22, 2024 | 07:34 PM
Pair of TLs's Avatar
Acura idle relearn procedure.
Old Feb 23, 2024 | 07:13 AM
Frankyy's Avatar
2014 TL
This is for a TSX but it’ll work for our TL’s
https://acurazine.com/forums/2g-tsx-...sition-944673/
Old Feb 23, 2024 | 10:32 AM
Just curious, did you manipulate / move the drive by wire TB butter fly valve on your 2010 TL as part of the 'toothbrush and rags' cleaning process?
Old Feb 23, 2024 | 10:58 AM
This is rhetorical, OP definitely did
Old Feb 23, 2024 | 05:07 PM
2010 WDP TL Tech
Unfortunately yes.
Old Feb 23, 2024 | 05:19 PM
Got the code checked out, it was P2279.
I should mention I did remove the intake manifold to clean everything also.
I went to a shop that specializes in Honda/Acura and the owner told me that it's because i didn't torque down everything correct so I have a air leak somewhere.
I doubt I didn't install the intake manifold correctly.
I went home, unplug battery, removed everything, and installed it again while torqueing down correctly.
Started up the car, held the RPMs at 3000 for like 30 seconds and let go (fans did not kick in yet). I was scared of holding my engine at 3000 RPMs for any longer, even though the instructions say hold it until the fan kicks in. I then let it idle for 5 minutes.
Went on a drive, and everything is MUCH better. Still not the way it was before, but much better. CEL came on, almost a minute after I started up the engine to go on the drive.
I want it back to normal, though, which includes no CEL.
I'm going to visit the shop again tomorrow and see what they think.
here you go,
Old Feb 23, 2024 | 10:02 PM
Unfortunately yes.
Check out post #10 on the thread below and listen to what ETCG talks about in the video regarding DBW TB's for clarification:
Open manifold to clean buildup? - AcuraZine - Acura Enthusiast Community
Old Feb 23, 2024 | 10:59 PM
2010 WDP TL Tech
Thanks. I know NOW I not supposed to move the plate. Question is HOW do I fix the idle issue!
Old Feb 24, 2024 | 06:57 AM
The 'fix' is there?
Keep in mind this is for a 3G TL DBW throttle body outlined in the 3G TL FSM.
It, the FSM 'Throttle Position Learning Check' process, depicted below, may or may not be similar to your 4G procedure?
I'm guessing that it is, because I suspect that your delicate DBW TB TPS is 'wacked' out of calibration due to your inadvertent butterfly valve manipulation from TB cleaning.
As you have learned, ETCG said in the video, "Don't move the throttle plate'; furthermore, before that you only see him spraying down the TB when cleaning.
Maybe one of your mates here, on the 4G TL side with a FSM can confirm / deny this process is similar by investigating for you?
The computer driven throttle position sensor may need to be recalibrated to regain a proper idle by either the HDS system or an aftermarket equivalent to return the butterfly valve to normal calibration.
If you mess up DBW throttle sensor position, in your TB by moving the buttery fly valve, you may need the below procedure or its aftermarket equivalent to reposition it for a proper idle.
Good Luck!
Old Feb 24, 2024 | 07:12 PM
2010 WDP TL Tech
Thank you all for your help. I bought a scan tool off of Amazon last night and reset the ECM and relearned the idle
Old Feb 24, 2024 | 08:29 PM
Which scan tool did you purchase?
So the scan tool had the specific throttle position learn check functionality needed to recal. the TB TPS?
It would be a good example to show this capability for Acura DBW cars, I may need one soon.
Old Feb 24, 2024 | 09:11 PM
2010 WDP TL Tech
FOXWELL NT510 Elite fit for Honda...
Amazon Amazon
piyerr
Feb 23, 2024 07:03 PM
MrVtech
Feb 28, 2017 09:12 AM
guitarplayer16
Jun 10, 2015 10:39 PM
Dan
Aug 19, 2013 11:38 AM
