Strange Grinding Noise From Driver Side Engine Bay
7th Gear
Hey Guys,
I just recently purchased a 2009 Acura TL and I am new to the forum. I have been trying to find an answer to this issue for a month or so now by looking around the forums to no avail. Im getting this strange grinding sound from my driver side sometimes at start up. It also occurs while I'm driving sometimes. It doesn't occur when I brake or turn the wheels. Just seems to make a slight grinding sound whenever it feels like it. I could be driving down the road or sitting idle. Car currently has 137k on it and did have timing belt replaced around 110k. I will try and get a video of the sound ASAP. Thanks guys.
If its the SH-AWD then chances are its the torque converter. I think the warranty was extended for bad torque converters but not sure if you still within range (I think it was ~100k miles?). At least ask a dealer or the Acura phone people to tell you if the software update was done on your car. All this, again, assuming its the SH-AWD.
7th Gear
Hey Tonyware,
Thanks for the response. My Acura TL is not the AWD version. only 3.5L Front wheel drive. with tech Package. I also uploaded the video of the grdinign sound it randomly makes. Sometimes it can be longer than this.
https://www.youtube.com/watch?v=z-9v...ature=youtu.be
7th Gear
Forgot to mention. You can hear it specifically at 4 seconds and around 18seconds in the video. Its usually pretty random when it does it and can last long than one quick second. And again, It can happen while driving or being idle.
Hey Tonyware,
The following 2 users liked this post by Tonyware:
echodigital (03-21-2014),
mmuschamp (03-22-2014)
mmuschamp (05-19-2020)
7th Gear
Thanks so much Tonyware! Since you've had this issue and death with it already. Would you say this is a possible do it yourself fix? How much did parts cost?
With a new belt it came to around $100. Can't remember exact number. Yes it is possible, its a 14mm bolt (or was it 12?) for the tensioner pulley and put the new belt back on by pushing that tensioner to the back with a wrench to fit the belt over the pulley. Just try to remember how the belt was on around the pulleys before you remove it. Pretty simple DIY.
rockyboy
08-04-2024 10:35 AM
sockr1
10-01-2015 01:31 AM
