Steps on how to replace 4G TL Air filter
Old Jun 19, 2010 | 03:00 AM
jrkkm's Avatar
Old Jun 19, 2010 | 11:21 AM
chaiwala's Avatar
Thanks for doing this!!! Should be a sticky and in the Garage.
Old Jun 19, 2010 | 11:24 AM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
GREAT write-up and pics!
Old Jun 19, 2010 | 03:01 PM
jrkkm's Avatar
Thanks. Just replaced mine yesterday and posted these pics.
Old Jun 20, 2010 | 08:25 AM
NwTSXmt's Avatar
So did you notice any performance gains?
Old Jun 20, 2010 | 10:40 AM
nyyanks81's Avatar
Thanks!!
Old Jun 21, 2010 | 12:09 PM
Kingmeow's Avatar
Great pics! People should do this each time they work on their car and we can build a huge repair library.
Old Jun 22, 2010 | 12:21 AM
jrkkm's Avatar
NwTSXmt: Not really. MPG is the same. Performance on responsiveness and acceleration a little bit but I do not know if it's because the air filter is new. If I had a brand new OEM filter to compare it with maybe.
Kingmeow: That will be great also if we can post video clips on a DIY section. I always try to look for something easy to fix my car that I don't have to pay $80 just to have it replaced. I also posted pics on steps on how to replace the cabin filter on a 4G. https://acurazine.com/forums/4g-tl-2009-2014-123/2009-cabin-filter-770128/
Old Jun 22, 2010 | 01:16 PM
NwTSXmt's Avatar
Thanks for the reply
Old Jun 29, 2010 | 10:50 AM
SHAWD10's Avatar
Nice job and great pics !!!!!! Thanks again
Old Jul 3, 2010 | 11:58 AM
omnimax's Avatar
Thank you!
Old Jul 19, 2010 | 01:38 PM
NOX 3.2's Avatar
TL-SHAWD 6MT Rocks!
Thank you for taking the time to indicate the clips and screw positions, and for taking clear pictures!
It makes all the difference in the world when repairing or modding our spaceships!
now we need one for the A/C filter.
Old Jul 20, 2010 | 04:40 PM
SHAWD10's Avatar
Here it is:
https://acurazine.com/forums/showthr...t=cabin+filter
Very easy.
Old Mar 23, 2011 | 02:33 PM
wakattack's Avatar
I wanted to add the following:
I just changed out the filter on my recently acquired 2009, The last fool who tightened down the screws went to far. They were over tightened, so when I went to remove them 3 of the four broke off. They are designed to break at a low torque amount, so that you do not damage the plastic housing by over tightening.
So when you tighten these up, go easy, go till snug and stop!
If yours end up broken like mine, you can get replacement screws in a pinch easily at Lowes or Home Depot, they are M5 .80 about an inch and a half long I think.
Which is what I did. However these could easily be overtightened and will not break like the OEM ones, and thus could crack the housing.
Old Mar 23, 2011 | 08:45 PM
vinnier6's Avatar
thank you
Old Apr 19, 2011 | 03:25 PM
Wooty Woo's Avatar
At mileage did you guys change your filter? I have yet to replace mine and I'm currently at 16,XXX miles.
Old Apr 19, 2011 | 03:26 PM
Wooty Woo's Avatar
Whoops, at what mileage*
Old Apr 20, 2011 | 01:00 PM
Kingmeow's Avatar
30k, normal driving condition. I think that's what is stated in the manual. I changed mine at 30k and it was dirty enough but not completely gunked up.
Old Apr 20, 2011 | 02:56 PM
Wooty Woo's Avatar
Thanks for the response!
Old Oct 21, 2012 | 06:17 PM
bbalestier's Avatar
Thank you I love my 2012 TL
I can hear the difference already I'll go for drive later.
Now how do you change those bright ass tweeters in front?
Originally Posted by jrkkm
Old Oct 23, 2012 | 10:15 PM
Crj5181's Avatar
where can i get this filter and will it fit 4g 2012 fwd?
Old Oct 23, 2012 | 11:10 PM
guerdy's Avatar
I've always used K&N drop in filters and have always felt that I saw a small but noticeable bump in performance. i.e., slightly better torque and low RPM response. Slightly better acceleration. I love the additional noises the car makes. However, the post on this website has me questioning my previous experience. Was it all my imagination or does anyone have some concrete objective results to share?
Old Jan 27, 2013 | 03:10 PM
docboy's Avatar
2010 TL AWD 6MT: New King
Good post, thanks. I was looking for the filter part number.
Old Feb 9, 2013 | 05:04 AM
AtotheZ's Avatar
Thx for the detailed procedure write up!
Old Apr 27, 2013 | 01:43 PM
Chrisdg19006's Avatar
What is the best tool to remove the screws? Mine were overtightened by the dealer tech that did the last replacement and I cant get them off with a phillips head or flat head screwdriver.
Old Apr 27, 2013 | 02:26 PM
LawnPro's Avatar
Scott
How about a ratchet and socket,?
You may need an extension too. I can't remember for sure.
Old Apr 27, 2013 | 02:53 PM
You're absolutely right about the ratchet and socket, probably dont need the extension since the screws are not pretty close to the top of the bay.
I decided to go for it and just used a wrench to manually remove the screws and two of the four broke . The two remaining ones came out OK. When all four were either removed or broken, I was able to replace the filter. Then I was able to remove what was left of the threads from the two broken ones with my fingers. I will be going to Lowe's this afternoon for replacements. In the meantime, I put the good ones back on opposing sides to secure the box as much as possible until I can get back from Lowes .
I might have mentioned earlier, that I am fairly new at this, just trying to learn how to be more self-sufficient when it comes to mechanical things.
Old Apr 28, 2013 | 05:57 PM
LawnPro's Avatar
Scott
Good to hear you were able to remove the screws. Anything mechanical with your car you can do yourself is great for your wallet, and know how for future car bonding......
Old May 2, 2013 | 09:24 PM
speedingbulletl's Avatar
Nice, I installed my typhoon myself.
Old Jul 13, 2013 | 10:06 AM
todd-tl-12's Avatar
4th Gear
Great Post..Thanks! I wish there was a dedicated DIY section on this site for this stuff.
Old Sep 26, 2015 | 02:59 PM
hashbrown's Avatar
Hey, looks like i came to right place. I've just gotten a 2012 TL w/Tech. It's almost 30k miles and i don't know if filter was ever replaced. Can we get the pictures of the install up again?
Thanks!
Old Sep 28, 2015 | 09:37 AM
hashbrown's Avatar
To answer my own question, i found a great video on YouTube detailing how to do this.
https://youtu.be/aIKhm-bJys0
Old Sep 30, 2015 | 10:37 AM
jim_c's Avatar
Tip for hard to remove screws
When you have difficulty removing a screw you have to take it easy and be patient. This often works but not always. In some cases a broken screw is easily replaced but at times it's a real hassle. If you can get the screw to turn at all, just turn it a tiny bit. Use the minimum torque possible. Do not use a big wrench on a small screw. Turn the screw back and forth to try to get it started. Loosen and then re-tighten to its original setting. Then loosen again. Each time you loosen you might get it a bit further. Go back and forth frequently and use some penetrating oil if possible. Take your time and often you can get the screw out without breaking it. Use some anti-seize when you put it back together.
Feb 25, 2020 09:57 AM
Skirmich
Sep 15, 2015 06:41 PM
Aleax
Sep 9, 2015 08:04 PM
sputik
Sep 7, 2015 01:40 PM
bymotion
Aug 31, 2015 05:00 PM
