Steering wheel POP and Rubbing noise
Our 09 has started to do this noise recently and not sure what is going on. The steering wheel when backing out of the garage it makes a pop and you can actually FEEL it through the wheel when it does this. I also noticed that the wheel when you rotate it left to right it makes a low rubbing type of noise and not smooth/quiet.
Any ideas what this might be and how to resolve it? Might have to take it in but trying to make them listen for it also might be a issue.
Something is definitely not right. And yes take it to the dealer and have it checked out. Had a similar issue with our Maxima and had them give me a formal print out of my complaint so that if something went wrong down the line, I would have a record of the complaint.
As for your TL, it should not be doing that at all.There is something going on with it. Bring it in and have a record of it.
https://acurazine.com/forums/4g-tl-problems-fixes-297/steering-noise-771710/
this is the link to an earlier post about the same and includes the tsb
and - https://acurazine.com/forums/4g-tl-problems-fixes-297/steering-wheel-click-sound-722954/
rockyboy
Jan 25, 2016 06:00 PM
