Squeaking in the Steering Column When Pressing the Start/Stop Button
When i get in the car and press the start button i hear a squeaking sound in the column. It is like something is engaging or something in there. I also hear the same sound when i turn the car off.
Any clue what it is? Worried labor will make this an expensive repair.
2010 TL SH-AWD
The steering column looks quite complicated once you remove the plastic cover that surrounds it. Best bet is to get a can of silicone lubricant with the little tube attached and spray where you see gears, joints, springs and so forth. At least it only cost $10 and 20 min of your time.
I had a squeak when turning the steering wheel and this had eliminate the noise.
