Shifts too early into 5th
During mild acceleration it will shift into 5th too early and shudder. If I step on it a little more it will downshift back to 4th. Under hard acceleration it's fine, or if I use the paddle shifters.
Would it be the 4th gear shift solenoid or the 5th gear solenoid?
My '13 does the same thing. It's designed to upshift as soon as reasonable for fuel economy. Yes, if at 40-45mph or so it's in 5th, and if you need only light acceleration it will shudder a bit. I had the dealer check it out a year or so after I bought it (CPO, 6 years ago) and they said it was normal. To me it just doesn't downshift quickly enough with light pedal pressure, but as you say more of a push, or paddle shifting, solves the problem. Since I was told it was normal I use the paddles. The 5sp in my 07 TL was more responsive to my right foot for downshifting than this transmission.
