Removal of driver side turn signal
Old Oct 30, 2009 | 08:41 PM
Kingmeow's Avatar
Only 3000 virgin miles and a rock hit my driver side turn signal and caused a dime sized spider crack. No puncture so I may just live with it as I don't think water will get in.
However, if I were to replace it, I see that it's held in with a 6mm bolt as evidenced by the exploded assembly diagram. What I am not too sure about is the electrical connection. Is the wire long enough to allow me to pull the assembly out and disconnect or do I have to go through the wheel well to disconnect first and then remove the assembly?
My suspicion is that it's long enough as the instructions for the front under spoiler kit says to remove the connection AFTER pulling off the bumper.
Please don't tell me I have to remove the bumper to do this!
Old Oct 30, 2009 | 09:08 PM
Kingmeow's Avatar
Oh sorry, it's the front turn signal, right above the fog light.
Old Oct 30, 2009 | 10:25 PM
venom550pm's Avatar
My beer fridge is in
you should be able to get at the wire from underneath the car, might have to remove some plastic gaurding, i don't quite remember. but it is just a quick disconnect to unplug from light housing. I don't believe you will be able to pull the wires through enough, if i remember correctly, they are ziptied to the bumper so they don't flop around.
Old Oct 31, 2009 | 10:01 AM
Kingmeow's Avatar
Thanks for the help.
Stupid me, if I only had read the manual! LOL! It says it right there in plain black and white on how to change the turn signal bulb so therefore I can do the disconnect first. You have to remove the corner air dam piece underneath and losen up the wheel well liner.
Now the question is whether to spend the $75 to replace it.
nanos
Nov 12, 2015 08:41 PM
JnC
Sep 11, 2015 06:06 AM
theinsvnity
Sep 10, 2015 10:22 PM
08 NBP TL
Sep 8, 2015 08:49 PM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
