New rotors and pads issues after install
Old Mar 29, 2013 | 10:17 PM
Osman.S's Avatar
Hello,
So I Decided on this Easter weekend to change my rotors and pads front and rear.
I installed the rotors and pads and everything seemed to be fine but my front passenger rotor gets extremely hot compared the drivers side and both rears.
The car does not pull when braking.
I did do a bed brake in as well after and still the same issue.
Do you think that passenger side rotor isn't fully releasing? Maybe I should check the slide pins again?
Old Mar 29, 2013 | 11:19 PM
Edward'TLS's Avatar
6G TLX-S
Jack up the front passenger end of the car, and check if you can rotate the wheel freely by hand.
The caliper may not have released completely, and is grabbing the rotor.
Old Mar 29, 2013 | 11:24 PM
arek1200's Avatar
Yes, check the pins ,make sure they don't stick and move freely,also make sure that there is not too much grease inside and you can push them all the way in with your fingers...
if that does not help ,it may be a sticky piston problem....
Old Mar 30, 2013 | 11:02 PM
3rdGenHybrid's Avatar
Make sure you Le caliper hose isn't twisted, sounds like that may be the cause.
Old Apr 4, 2013 | 08:26 PM
nuckles 3.7's Avatar
Check the piston caliber maybe u did not compress it in all the way
HOWELLiNC
Sep 10, 2015 01:39 PM
asahrts
Sep 4, 2015 05:55 PM
nishant11
Sep 2, 2015 10:34 AM
