09 TL AWD Hesitation when Turning
Old Mar 31, 2013 | 11:25 PM
eez4life's Avatar
Hey everyone. I have been recently having a problem with my car hesitating when turning. I'll make the turn and try to accelerate but the car will feel bogged down for a split second and then accelerate. It happens when the car is warm or cold. Also happens on both right and left turns. Anyone having a similar issue?
Old Apr 1, 2013 | 12:17 AM
eez4life's Avatar
Forgot to add: Auto trans. This happens under normal conditions meaning I am not punching the gas. Can happen when pressing accelerator around corner and braking around corner...makes no difference.
Old Apr 1, 2013 | 02:42 PM
MoAbbas's Avatar
moabizzi
i think thats just the normal acceleration delay everyone is feeling. does it happen when your driving straight?
Old Apr 1, 2013 | 08:55 PM
eez4life's Avatar
No. This just started recently. I know the normal hesitation. This feels more like the car is deprived of gas and is about to die but then goes back to normal. I guess its hard to explain until you feel it. Thanks for the input.
Old Apr 3, 2013 | 11:14 PM
VQPower37's Avatar
how many miles on the car? ... when was the last time u changed ur diff fluid?
Old Apr 4, 2013 | 08:40 PM
diamondmit's Avatar
Most likely is an overactive traction control....you're in Illinois and there's still a good amount of sand and cinders on the road. When you turn, the inside and outside wheels turn at a different rate because they are tracing the radius of different circles, with the outsides spinning faster than the inside. But I digress. The car will bog and you should get a brief flash of the yellow warning light on the dash. Have you noticed this? Look for it and see if that is the culprit. I get this bog from a simple turn near my office. You can also shut off traction control and try problematic turns with and without TC turned on. Let us know how this plays out.
best
dd
rockyboy
Aug 4, 2024 10:35 AM
Frathora
Sep 28, 2015 11:29 PM
heykosal
1G RDX Problems & Fixes
Sep 21, 2015 09:41 AM
ostrich
Sep 11, 2015 04:28 PM
aces2412
3G MDX (2014-2020)
Sep 7, 2015 08:40 PM
