Manual Transmission Fluid Check
Old Feb 28, 2016 | 05:17 PM
nsps's Avatar
Can someone describe or take a picture of exactly were the bolt is to check the manual 6 speed transmission fluid level on a 2010 TL? I know where to drain it and fill it but I can't find the check fluid level bolt.
Thanks in advance,
Rob
Old Feb 28, 2016 | 05:31 PM
Aman's Avatar
Your Friendly Canadian
Many manual transmissions don't have a dipstick to check fluid level, if that's what you're asking about.
Old Feb 28, 2016 | 08:20 PM
Marmbo's Avatar
This might help?
Old Feb 28, 2016 | 08:56 PM
nsps's Avatar
I've seen that and it looks simple, but I can't see it. I'm sure it will be so obvious once I've actually found it.
Old Feb 29, 2016 | 08:02 PM
Marmbo's Avatar
I think there should be some sort of electric wires that go through a plate somewhere around there as well. That's about all I can say.
Old Mar 1, 2016 | 10:10 PM
JasonK's Avatar
09 TL SH AWD /w TECH
The drain plug for the tranny should be a 3/8's plug that goes into the tranny. Usually you want the level to be right at it. So when you open the plug some tranny fluid should come out meaning it's at level. Would be easier to check this with a hoist. You'll have to look at the tranny underneath the car. It won't be ontop.
hondu
3G MDX (2014-2020)
21
Jun 28, 2020 10:37 PM
Costco2
2G TSX Problems & Fixes
Mar 31, 2019 02:21 AM
Kesler123
Feb 27, 2016 10:12 PM
Hammer Time
Feb 27, 2016 05:12 PM
FRobledo05TL
Feb 13, 2016 06:15 AM
