Lock Button on Door Handles Not Working
Old Aug 12, 2013 | 02:50 PM
Egotist's Avatar
I have the keyless ignition on a 13' tech.
Like the title says the button on both doors stopped locking the car a few days ago. The remote fob will lock the doors when I press the lock button so I know the motors are fine. Also the doors will unlock when you put your hand in the handle.
It doesn't work with either the driver #1 or #2 key fob.
I searched and wasn't able to find anyone else with this problem. I'm certain it's a setting I'm missing not an actual "problem" but I can't seem to figure it out. I'd rather not waste an hour of my life with a dealer visit.
Old Aug 13, 2013 | 09:30 AM
CerberusKy's Avatar
did the switch in the glove box accidentally get switched to off?
Old Sep 19, 2013 | 01:14 PM
Sportschicfla's Avatar
I am having a similar but different issue with the door handle lock. Mine works fine to lock the doors, but there doesn't seem to be away to unlock all the doors using the driver side handle. The passenger & hatch handle both will open all doors fine.
Any ideas?
Old Sep 19, 2013 | 07:02 PM
echodigital's Avatar
From TL to RDX
It maybe on page 130 in the TL manual:
http://owners.acura.com/vehicles/inf...013/TL/manuals
Old Sep 20, 2013 | 07:54 PM
Any ideas?
I have the RDX....I have found the settings on the dash display but there doesn't seem to be one for this.
Old Jan 13, 2014 | 06:13 PM
Sugi's Avatar
My Driver's side Door Lock Button is broken. It started as an intermittent fault and is now completely unserviceable. Passenger side works 100%. Has anyone had this fixed? If so what is the failed part? Thoughts on quick fixes other than taking it to the dealer.
Old Jan 13, 2014 | 06:56 PM
Tonyware's Avatar
'20 TLX SH-AWD A-Spec
Unfortunately same issue here. It won't lock when I use the door handle button. I am thinking of warming it up with a hair dryer tomorrow and see what happens. However, I also tried to insert the actual key and it won't turn. Can someone try to re-create this?
I suspect ice may have cause some damage in the entire mechanism inside that part.
Old Jan 21, 2014 | 06:36 AM
Tonyware's Avatar
Now both passenger and driver buttons quit working. Another reason may be that the sensors think there is a key fob left inside the car so they don't lock. Cold climate testing is very tricky.
I think Acura needs to do some more cold weather testing on long term components, not just take a new car and test it in the cold. They need to go from cold to warm and back to cold with the same car over a period of time to detect all these small issues.
If the mechanism has died, the outer handle part is around $140 x 2. But the process to change it is not an easy one!
Old Jan 21, 2014 | 09:40 PM
JasonK's Avatar
09 TL SH AWD /w TECH
Sounds like a sensor issue.
Old Jul 18, 2014 | 11:25 AM
ACM's Avatar
ACM
5th Gear
Sugi, did you ever get this fixed? I have the exact same issue and it developed in the same way: intermittent failure followed by complete failure. The passenger switch doesn't get used nearly as much, which is probably why it still works 100%. I suppose I could move the passenger-side switch to the driver's side, but I'd rather not open up both doors if I don't need to.
I'd be interested to know if you went the DIY or dealer route, or if you're just living with it for now and locking with the fob.
Old Jul 18, 2014 | 11:09 PM
From TL to RDX
I had dealer fix it under extended warranty. The whole handle was replaced.
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
tman570
Jun 11, 2019 07:56 AM
acurajj
Sep 19, 2015 03:47 PM
ahsm
Sep 9, 2015 08:35 AM
