Location of HFL
Old Mar 11, 2013 | 04:19 PM
TJ Zooker's Avatar
Location of HFL
Wondering if anyone knows where the hfl is in 2009+ tl's. Have a phantom battery drain and want to disconnect it to see if its the culprit like in the 3G tl's
Old Mar 11, 2013 | 05:15 PM
potmilkz's Avatar
isnt there a fuse for that?
Old Mar 11, 2013 | 09:17 PM
TJ Zooker's Avatar
Maybe, will have to check. Also have an aftermarket car starter that might be the problem. Doubt it though. Just had the battery checked from where I purchased it and it was good. Thats why I am assuming its the hfl bluetooth module. Checked out the charging system with my multimeter and it all checked out. Hate this electrical bs.
Old Mar 12, 2013 | 09:04 PM
TJ Zooker's Avatar
Looked for hfl/bluetooth fuse, unable to locate
Old Mar 12, 2013 | 10:08 PM
TJ Zooker's Avatar
So using my multimeter and watching the amperage draw (which was about 230ma, in the unacceptable range) I started to pull fuses and watch the multimeter. I started with the fuse box under the hood and as soon as I pulled fuse #15 (which is the "backup 10A" fuse) my draw was reduce to 10ma which is in the green range. Which is the fuse for audio, hfl/bluetooth, interior lights and a few other accesories. So pretty sure its the hfl if I could find it...
Old Mar 13, 2013 | 08:30 AM
Oswald Vater's Avatar
I know that in the 3g it was located in the overhead console where the sunglass holder is. Not sure if it's in the same spot in the 4g but don't see a reason for them to have moved it. I had it replaced in my 3g when I had it for the reason you stated.
Old Mar 13, 2013 | 08:59 AM
TJ Zooker's Avatar
Ya I checked there thoroughly and was nowhere to be seen. Tried a dealer, said they would call me back but never did. Warranty is up as well.
Old Mar 13, 2013 | 10:15 AM
09tl3.7's Avatar
i know some car starters are always sending signals to the remote to verify range. Hope you resolve the issue
Old Mar 13, 2013 | 10:38 AM
TJ Zooker's Avatar
Tested the amp draw with remote modules plugged in and unplugged and there was little to no change. Still convinced its the hfl. Going to see the service manager today and maybe he can tell me where it is.
Old Apr 8, 2015 | 03:57 PM
j.riderknives's Avatar
Were you able to find the location?
My HFL button doesn't do anything and I can't connect my phone.
I'm assuming it's the HFL unit, but can't find anything on the internet.
Thanks,
Josh
Old Apr 10, 2015 | 05:12 PM
'99-6SIC6's Avatar
It's #15 in the picture fellas...to the right, rectangle...
-greg
Old Apr 10, 2015 | 09:43 PM
Thanks for the reply.
This exploded view is kind of difficult to understand.
Is the module behind the center console or near the glove compartment?
Old Apr 12, 2015 | 04:17 AM
wb12859's Avatar
here ya go
Jul 16, 2017 07:33 AM
vpasla1
Sep 17, 2016 07:24 PM
MetalGearTypeS
Aug 29, 2016 08:28 PM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
malvothegreat
2G CL Problems & Fixes
Sep 29, 2015 08:00 AM
