Light on ignition button
There is what looks to be a little light on the TL's ignition button. I have never seen this light (if it is a light) turn on. When I had a Prius as a rental, I took note that pressing the brake pedal illuminated the light on the ignition button indicating you can now press it to start the engine. Does this work similarly in the TL?
Basically, I am trying to determine the conditions, if there are any, under which this light (if it is a light) would turn on in order to find out of it should be fixed by the dealer.
I just tested this and I can confirm that the light turns on when in accessory mode and "on" mode, but not when the engine is running. Thanks Eli! It's good to know there isn't a problem with that, at least.
mada51589
Jan 9, 2025 04:40 PM
rockyboy
Aug 4, 2024 10:35 AM
Soul_Deamon
4G TL Problems & Fixes
Nov 2, 2015 04:32 PM
