Just dodged a big bill
Old May 9, 2013 | 04:34 PM
mrclemson's Avatar
NTL FWD, < 25K miles. ABS/VSA lights were on last week, driver door lock was making a grinding noise.
Turned out the ABS/TCS/VSA modulator was bad, the part 57111-TK4-A14 along costs like $1.5K. The lock was due to a latch assy, which is cheap.
They also noticed that the battery failed the test. Voltage was 12.62V, measured at 451 CCA @ 70F, rated at 550 CCA. Dealer replaced it under warranty.
I have been using the same dealer for years. In general, they fix issues in a single visit.
I expected Acura to be more reliable though.
One quick question: while they did bleed the system as shown on the paper work, the brake definitely feels a bit more spongy, the pedal travels a lot longer than it used to, do I need to worry? Or it will come back to "normal"?
Thanks.
Old May 9, 2013 | 05:08 PM
no, the brakes needs to be re-bled.
Old May 9, 2013 | 08:00 PM
Little Gator's Avatar
When doing a typical brake fluid flush & bleed of the 4 calipers & lines, how does this task get the brake fluid out of the ABS system?
Old May 9, 2013 | 08:49 PM
mrclemson's Avatar
Thanks. The invoice showed 2 12oz brake fluid, does this look right to you? Or it's definitely not enough.
Thanks.
Old May 9, 2013 | 10:28 PM
CerberusKy's Avatar
Sometimes they use a vacuum pump to bleed the brakes, i find this to be not as effective as using the 2 person method (one pushing the brake pedal, one managing the wrench).
Old May 10, 2013 | 09:09 AM
mrclemson's Avatar
Another observation was when I can step down the brake pedal a few inches after pumping the pedal a few times, without starting the car. Is this a good indicator that there is air? I tried the same on my wife's car, hers barely moved. Anyway, calling the dealer. Thanks.
Old May 10, 2013 | 10:11 AM
Thanks.
24oz is enough
if its "spongy" then there is air in the lines.
Jul 16, 2017 07:33 AM
Jinkazetsukai
Nov 21, 2015 05:28 PM
Froid
Sep 27, 2015 06:16 PM
