HID flicker. Xentec HID kit h11
hey guys, im having an issue, i recently purchased Xentec Hid for my fogs, and when its all done and installed, the hid on the passanger side flickers or you can say it twitches..
anyone experience this issue? would relay help?
2 options
1) install Relays (preferred method)
2) Upgrade your fuses to 20AMP... in your driver and passenger cabin fuse boxes, there is a micro 10AMP fuse for each fog light. you can pick them up from a honda or acura dealer.. Some auto stores are starting to carry them (its a newer, ultra small fuse). should cost about $2-$4 each. worked for me on my WDP 4G
2 options
nice i will try this and let you know. i was about to install relays, but if this works the same way, then why not lol.
^ really? you changed the really tiny fuse in both the driver side interior, and passenger side fuse box?
worked on both of my 4Gs.. one had a Kaixen kit, the other was phillips... i might wonder if its your HID kit that is causing the flicker
another thing to try. start the engine before igniting the fogs.. if they still flicker, the problem really might be elsewhere..
in the end, a relay is really the best option to use. its safer for your electrical system
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
