Hesitation/Misfire on Acceleration
My new-to-me 2011 Acura TL is exhibiting intermittent hesitation upon acceleration and there is no check engine light. Maybe I have bad luck because it seems like three of my past four vehicles have done this and I never determined the cause. It seems to occur between 1,500 and 3,000 RPM but once the RPMs get above 3k it accelerates like a bat out of hell. I suspect maybe it's one or more of the coil packs because the previous owner had three of the six replaced shortly before selling it, but if that were the case I would think it would get worse at higher RPM, not better. I've seen these bluetooth and USB diagnostic dongles that plug into the OBDII port and supposedly monitor all of the vehicle functions in real time using a smart phone app or laptop. I'm wondering if this type of tool will allow me to pinpoint what is happening. I've seen several for under $50. Anyone use one of these and successfully diagnosed an engine related issue? https://www.amazon.com/gp/product/B0...=ATVPDKIKX0DER
if its not throwing a check engine light, the obdII readers wont do jack chit..
the obdII readers are the same readers they have at autozone...so if you dont live in cali, you can get the car checked for free....instead of spending >$50...
you're going to have to trouble shoot.....physically.
why were the coils replaced?
leave engine on and unplug each coil one at a time....engine note should change... if engine note does not change, you have successfully troubleshooted...
I have an OBDII reader, but this other product is supposedly for recording parameters in real time so you can monitor them while driving. The coils were replaced because the engine was misfiring badly. I'll measure the primary and secondary coil resistance and see what it is. I've heard some coils don't exhibit problems until the engine warms up, so I suppose I should test them when they're hot. Or take each one out and hit them with a blow dryer while monitoring the resistance
you need a cylinder compression test and a leak down test
No, it's a 5-speed automatic (3.7L SH-AWD). The shop apparently told him it was caused from bad gas. I believe they replaced all of the spark plugs and two or three coils. Coils failing from bad gas is obviously bogus, so it makes me wonder if the others are on their way out as well.
but trying to point you in the right direction
check and see if the transmission software was updated as the old software damaged torque converters.
Yeah, I know. That's because I haven't had a chance to dive into it yet. I've only had the vehicle for a couple months and it's been sitting for over half of that time because of the airbag recall. I'll do some basic checks (coil resistance, compression, leak-down, etc) and post back at a later date. Unfortunately, it looks like I need and HDS tool to disable the injectors in order to do a compression test. However, a leakdown would be more comprehensive anyhow.
a failing catalytic converter can also cause hesitation
My best guess is they don't provide them because it's not a tell-all. In other words, the resistance can be within spec, but that doesn't mean the coil is functional. I'll have to take some measurements with an o-scope to gauge their health.
Robert Paulson
Mar 22, 2018 08:34 AM
RysTL04
Jun 13, 2016 05:38 PM
JordanUa7
Jun 7, 2016 11:30 AM
stizzylita
1G TSX Problems & Fixes
Feb 22, 2016 07:22 PM
