Help with replacing rear wheel hub assembly
Old Sep 24, 2019 | 02:52 PM
Twin5761's Avatar
I'm in the process of replacing the rear hub, but what I'm stuck at is having the 36mm bolt turning where I can't get it off. Any suggestions would be greatly appreciated.
Old Sep 24, 2019 | 02:55 PM
did you use a chisel to undo that little indent?
then you get an electric impact or a breaker bar with extra extensions and go to town
PB blaster soak goes a long way as well.
Old Sep 24, 2019 | 02:59 PM
Twin5761's Avatar
I don't have a chisel I did use a Flathead and a hammer.
Old Sep 24, 2019 | 03:03 PM
Twin5761's Avatar
Old Sep 24, 2019 | 03:08 PM
Okay, now soak it with some PB blaster or take a torch to it for a bit and then grab a breaker bar and go to town
It's a tough nut to crack (pun intended ) or get an air ratchet.
Old Sep 24, 2019 | 03:12 PM
Twin5761's Avatar
Lol.... I have a breaker bar but what I don't understand is how do I get the hub to stop moving so I can take the nut off???
Old Sep 24, 2019 | 03:34 PM
Twin5761's Avatar
Can anyone help me out?
Old Sep 24, 2019 | 03:51 PM
losiglow's Avatar
Wedge something between the lug studs and the ground so that the hub doesn't move. I have a 3 foot prybar that I use.
losiglow's Avatar
Another idea - put the rotor and caliper back on, have someone press the brakes while you use the breaker bar to break the nut loose.
Old Sep 24, 2019 | 03:53 PM
Twin5761's Avatar
Thank you so much, I'll try that.
Old Sep 24, 2019 | 08:58 PM
Twin5761's Avatar
Jeez that was a PITA getting that nut off....but I got it done. Thanks for the help man.
Old Sep 24, 2019 | 09:41 PM
Twin5761's Avatar
This might be a dumb question, but I need an alignment after this repair?
Old Sep 24, 2019 | 09:55 PM
Not necessarily but depending on how hard you manhandled it, you POSSIBLY could have pulled it out of toe. If you haven't done ones in a while , now is as good of a time as any
Old Sep 24, 2019 | 10:00 PM
Twin5761's Avatar
Okay, the cars doesn't seem to drive different, but as you said I think that would be a great idea.
Old Sep 29, 2019 | 07:47 PM
Reorge's Avatar
It's MUCH easier to remove the axle nut before you jack up the car and remove the tire.
While wheel is on the ground remove the rim center cap to gain access to the nut.
Once nut is loosened then you can jack up the car.
.... at least that's how I've removed front axle nuts on Honda/Acura cars.
SLAYER6669
Aug 2, 2012 08:43 PM
dennisil
Mar 24, 2012 01:22 PM
timeizmoney22
1G CL DIY & FAQ
May 9, 2011 10:03 PM
clrider665
Aug 9, 2007 10:07 PM
