Rear Hub Help
Old Mar 23, 2012 | 10:55 PM
dennisil's Avatar
Rear Hub Help
I'm hearing grinding noises coming from my right rear wheel. I was looking for a DIY on replacing the rear hub/bearing I got the parts today I'm hopeing to work on it tommarow please help me find a DIY or and diagrams of the rear bearing and hub
Old Mar 24, 2012 | 01:22 PM
invalidalias's Avatar
It comes as one whole assemble. You will need a stout 32'' or 36" mm socket and one strong impact.
Remove:
Tire,
aluminum cap
caliper
rotor
spindle nut (32mm or 32mm)
gearing/hub assembly slides off
You have a drum brake in rear for e'brake. Make sure the e brake is NOT engaged when you remove the rotor
foxriderar77
Nov 19, 2020 10:17 AM
BoricuaTL
Apr 8, 2016 01:08 PM
obert
Nov 14, 2015 09:59 PM
neuronbob
Sep 19, 2015 10:45 AM
jmoney2001
Sep 11, 2015 12:07 PM
