Help with engine code P0335
Old Sep 23, 2021 | 10:55 PM
volcomstonebus's Avatar
3rd Gear
I need opinions/help
Recently replaced my oil pan due to mechanic before stripped my oil pan which cause my plug to be over stripped. After replacing the oil pan this message popped up. I replace the crankshaft position sensor that js connected to my oil pan and this code is still popping up.. does the crankshaft need to be resync? Or it is more serious now?
Old Sep 24, 2021 | 08:39 AM
take it to a mechanic who has a bi-directional scan tool. bi-directional meaning the scan tool can read codes and also activate actuators and such.
the mechanic will be able to scan the car for any codes, delete the codes to see if they come back up. if they do come back up, the mechanic then will be able to do a CKP(Crank Position) learn with the scan tool.
6SpeedT
1G TSX Problems & Fixes
Sep 4, 2021 10:08 PM
awats
2G TSX Problems & Fixes
Apr 9, 2021 08:03 AM
meissama
2G CL Problems & Fixes
Nov 1, 2017 07:47 AM
systemtwentyone
Aug 3, 2015 01:33 PM
Dnguyen92
May 25, 2013 02:54 AM
