Grinding noise while turning right
Old Jun 28, 2010 | 10:11 PM
chaiwala's Avatar
Angry Grinding noise while turning right
I have this odd problem where driving slowly 15mph or slower, after turning right and gently accelerating, I hear a grinding noise coming from the vicinity of the passenger side wheel. The sound is similar to when you are on a plane and you can hear and feel the landing gear being let down. This sound is more prevalant when the car is cold but it sometimes happens when the car is under optimum operating conditions as well but very very rarely.
Anybody else with this symptom? Did a search and did find some issues with the power steering fluid but since ours is electronic, this cant be the problem.
Guesses anyone?
Old Jun 29, 2010 | 01:02 PM
chaiwala's Avatar
Bueller, Bueller anyone? BUMP
Old Jul 4, 2010 | 12:06 PM
Rocketsfan's Avatar
I'm not sure what sound you're hearing, but if it sounds similar to the sound my 3G was making, it ended up being a faulty power steering pump that was replaced under warranty. Your description sounds similar to what I was experiencing. Get it checked out if you haven't already.
Old Jul 4, 2010 | 03:50 PM
crxb's Avatar
happens after starting car? - if so could be the abs unit start up sound?
Old Jul 4, 2010 | 10:23 PM
chaiwala's Avatar
Yes, that is the common solution but the 4th Generation has an electrical power steering so no pump. Thanks for the advise. I am going to get it checked out but its very hard to duplicate this as it only does it when cold. Sometimes will do it too under normal temps but very very rare.
Old Jul 4, 2010 | 10:28 PM
chaiwala's Avatar
Well, its after starting when cold but only after I take a right turn, so I turn right and then when I slowly accelerate after turning is when I hear the grinding noise. Does this every single day but only when taking a right and only when the engine is not quite warmed up. Kind of like a 2 liter bottle of cola crunching or similar to hearing landing gear coming down in an airplane just not as loud.
Old Apr 15, 2016 | 02:26 PM
schrefftl's Avatar
Did you ever figure out what was causing the grinding noise when turning right? I am experiencing the same issue. It is a very loud grinding sound when turning right.
Old Apr 15, 2016 | 08:29 PM
JasonK's Avatar
09 TL SH AWD /w TECH
Probably a bad wheel bearing.
Old Apr 16, 2016 | 12:01 AM
Pearson4G's Avatar
Was getting the same sound back in December and it ended up being a bad CV shaft. Had to get the shaft and boot replaced.
Feb 25, 2020 09:57 AM
jblessing
Aug 8, 2018 09:43 PM
Frathora
Sep 28, 2015 11:29 PM
PortlandRL
Sep 14, 2015 12:01 PM
aces2412
3G MDX (2014-2020)
Sep 7, 2015 08:40 PM
