GPS antenna
GPS antenna
Hi! I have a 09 Acura TL.My Navi quit working. At the same time, my clock and voice feedback went out. I went through the diagnostic and my "GPS Ant" was red. I just wondering where the GPS antenna is located? Thanks in advance.
Its on the dash, behind the navi screen. It could be as easy as the #15 fuse in the engine bay fuse box, causing the anti-theft to kick in, preventing the use of the navi. Also check your battery, low voltage? It may be going bad and the navi is just the first victim!
Only thing I could think about is metallic window tinting. A few easy things to do, like disconnect the battery, reconnect and re-enter the anti-theft codes. But, the system saves trouble codes, hard errors etc. There is a way from the menu to download them to a USB key to look at the errors in more detail. Worse case scenario the entire unit has to be replaced.
blacktsxwagon
Oct 27, 2015 10:12 PM
us285126
Oct 2, 2015 02:03 PM
oyayjoe
Sep 12, 2015 04:40 PM
