Fuse for seat memory
Old May 2, 2012 | 07:02 PM
JDWheelz's Avatar
Anyone know which fuse is involved with the seat memory buttons on the driver door? Just realized my buttons aren't working. Can't program them, no green light, no action, etc. followed the instructions in the manual to be sure I was in Park with E Brake on but still nothing.
Old May 8, 2012 | 03:25 PM
invalidalias's Avatar
Looks like it could be either of the following fuses to check:
(You could have a bad switch too)
Driver Under dash fuses-16,12,24
Under hood main fuse box (the triagle shaped one) fuse 15
good luck
Old Sep 13, 2013 | 12:10 PM
billun1063's Avatar
4th Gear
Did you ever get this fixed? I am having the same problem and the fuses listed in the reply don't seem to be correct.
Old Sep 13, 2013 | 01:22 PM
jim_c's Avatar
Is there a map in the manual that IDs all the fuses?
There is for my wife's Camry, very helpful.
Haven't looked into the TL manual yet but I would assume it's there. (?)
Old Sep 16, 2013 | 04:19 PM
billun1063's Avatar
4th Gear
Ya I found that but it doesn't list anything specific to the driver memory and the ones listed in the previous post don't look correct.
Old Sep 16, 2013 | 04:35 PM
jim_c's Avatar
OK I see what you mean. Unfortunately I was also into my fuse boxes today, dammit, and they are difficult to ID. My stereo died. I did not manage to find the fuse so I gave up after a few tries.
Old Sep 17, 2013 | 09:00 AM
billun1063's Avatar
4th Gear
I have an appt at dealer tomorrow. I will keep you posted. I live an hour away from the dealership and have to make a special trip just for this
Old Sep 17, 2013 | 09:04 AM
Edward'TLS's Avatar
6G TLX-S
I have taken a picture of the driver side fuse box label, back a long while ago :
Old Sep 17, 2013 | 04:36 PM
jim_c's Avatar
That's very good of you, but no one seems to know which fuse controls the stereo or the seat memory. There's no code for all those acronyms.
Old Sep 19, 2013 | 10:52 AM
billun1063's Avatar
4th Gear
So I drive 60 miles to dealership. The guy pushes the set button and it fricking works. Maybe when I was checking fuses I reset something but if that is the case I still don't know which one it was. Oh well at least it works now.
Old Sep 19, 2013 | 12:13 PM
4GTL's Avatar
Noticed this mysterious problem in my 2012 a few times. It seems like after I drive a while, push every single button in the car, and somehow it works again....
Old Oct 19, 2013 | 08:18 PM
91lgndsdn's Avatar
I am having the same problem. I remember it happening a while back and it miraculously started working again. Anybody found out why this happens? Could it be something with the switch or the computers memory electronics? Wonder what would happen if I disconnected the battery for a few seconds?
Old Oct 19, 2013 | 10:18 PM
91lgndsdn's Avatar
Well persistance finally paid off. Disconnecting the battery did nothing. A ran a search for seat memory issues and ran across a post on "would you believe it" a Lexus site thread.
Here's what it said, "Make sure you are in park with ignition ON. Assuming you are....
This sounds like the problem which occurs after power has been disconnected. The seats have to be "re-taught" their limits before the memory will work.
You should check your manual because I think different years have different procedures. Here's a couple posts from another thread:
What you have to do is move the seat back all the way forward using the power seat back switch until you hear a beep , then move the seat cushion back the entire way again using the power seat control, next move the seat cushion all the way forward using the power control. You can now put the seat in the position you desire and push set and #1.
1. Move the seat forward until you hear a beep.
2. Move the seat all the way back.
3. Move the seatback angle switch forward until you hear a beep
4. Move the seat back angle switch all the way reclined.
5. Set the memory now."
I got in and with the ignition on I moved the seat forward and then back, seatback forward and then back all the way. I did not really hear any beeps, but after cycling through the movements the seat memory functions again.
Old Oct 27, 2013 | 12:25 AM
AcuraChick79's Avatar
3rd Gear
Thank you so much for researching this! I just recently started experiencing this issue & will give it a try tomorrow
Old Nov 19, 2013 | 08:45 PM
Jay Keddy's Avatar
Thank you, I was having the same issue after my battery died a few weeks back
Old Nov 7, 2022 | 11:55 AM
cairo333's Avatar
Thank you! It works!!
MrHeeltoe
20
Feb 23, 2023 01:54 PM
tsx_boy
Dec 13, 2019 08:33 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
hashbrown
Sep 29, 2015 12:13 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
