Fob holder won't reset after pulling key out
Old Apr 21, 2013 | 11:12 AM
Gregan1209's Avatar
3rd Gear
Hey all,
I have a 2009 TL SH-AWD. Recently I parked the car and turned off the ignition. I pulled the key out as usual (didn't force it and it provided no in-usual resistance). My display came up saying to remove the key and the chimes were going off even though the key was out. I read on a post that you can pull out a clip inside the fob holder so I did that and the problem stopped. AWESOME!!! Problem is that the part you pull out doesn't reset itself again after you pull the key out, it comes up with the display and chimes again. I figure before I go get raped to replace this I may as well try my luck in hopes one of you may have a resolution.
Old Apr 21, 2013 | 12:08 PM
Edward'TLS's Avatar
6G TLX-S
If the key slot has worn out and require replacing, then don't use the key slot to start the car.
Switch on the keyless start system, and use the key as proximity sensing instead.
Old Apr 21, 2013 | 01:36 PM
Gregan1209's Avatar
3rd Gear
Yeah, I understand. It's just the fact that its broken and I'd rather it not be. I'm willing to take it in but would rather try to fix it myself first.
Old Apr 21, 2013 | 02:52 PM
Edward'TLS's Avatar
6G TLX-S
Not too long ago, there was a thread that the OP was having similar key slot problem, and was also planning to take apart the dash to replace the key slot DIY.
Don't know how it went. Do a search if you're interested.
Old Apr 21, 2013 | 04:02 PM
Tonyware's Avatar
'20 TLX SH-AWD A-Spec
Maybe this?
https://acurazine.com/forums/4g-tl-2009-2014-123/keyless-entry-slot-790732/
Old Apr 21, 2013 | 06:45 PM
Gregan1209's Avatar
3rd Gear
I appreciate the link, I went out and tried it as described but couldn't get it to reset on its own when you shut the ignition off. Ill take it in and post what they say it was on here for future reference. Thanks for the ideas.
Old Jul 26, 2013 | 10:11 AM
CarrieLynn's Avatar
guys, this seems to be a common problem and happened to me this morning.
Nothing is broken and nothing needs to be replaced. You do not need to go to the dealer.
Reach into the key slot with 2 fingers and you will feel something that feels like 2 small teeth. They are connected to the part that slides in and out when you insert your key. Those teeth hold your key in.
What has happened is when your key was last removed the assembly that holds your key in did not slide out with it therefore the car thinks the key is still inserted. Thats why you are getting the "please remove key" message on the MID.
You just need to manually pull it out. I did it in less than 5 seconds and I did not need to apply a lot of pressure or pull too hard. You do not need any special tools. If your fingers are too large to fit in the key slot I suggest you find a nice lady with smaller fingers to assist you
Old Jan 7, 2014 | 11:09 AM
gibbyisgibby's Avatar
THANK YOU!
Old Jan 7, 2014 | 10:57 PM
real_mckoy's Avatar
dude i know u gonna get multiple thanks or this i even thanked you and i dont have that prob knock on wood though and i know right away i do understand what your talking about...
Old Jun 11, 2020 | 02:19 PM
Biggavelli's Avatar
Thank you!!
Thank you bro! You just saved me from paying acura $150 just for a diagnostic! & who knows how much they were going to charge me! I put my fingers in and boom good bye to the message! 🙏🏽
Old Sep 12, 2025 | 06:02 PM
sexyhoagie's Avatar
I just made this account to say THANK YOU!!! A+!!!!
Old Jan 4, 2026 | 06:56 PM
ACM's Avatar
ACM
5th Gear
Yeah, this worked for me too, years later. Hold the key fob flat in your palm and look at the edges, and you'll see a small notch on either side that hooks into the "teeth" inside the slot. That'll give you an idea of where to feel for, and pull.
rockyboy
Aug 4, 2024 10:35 AM
SidhuSaaB
May 30, 2020 12:40 AM
eastsideride
Oct 15, 2015 04:26 AM
VA2000TL
Oct 2, 2015 08:26 AM
agupta3224
Sep 22, 2015 08:08 PM
