Engine making weird noise and rough idle
Old Mar 22, 2025 | 04:30 AM
RachelRedFox's Avatar
6th Gear
Hi Acura lovers,
I am concerned about my engine in my 2012 TL, it has a rough idle and when I popped the hood the video below is what I heard. Has anyone else had this problem before and if so what was the cause?
File Type: mov
Old Mar 22, 2025 | 06:56 AM
altair47's Avatar
Originally Posted by RachelRedFox
Hi Acura lovers,
The sound is fine, that's how it should sound.
Old Mar 24, 2025 | 10:02 AM
Flyinblyian's Avatar
I concur with altair47, that sounds perfect. Mine may be a little quieter after getting the valves adjusted last year.
Old Mar 26, 2025 | 09:21 AM
6th Gear
Update on problem
Took my car into service and they say the motor mounts are starting to wear out, which is causing the rough idle and vibrations
Old Mar 26, 2025 | 09:45 AM
I was actually going ask about the rough idle/vibrations symptoms as we who replied about the noise didn't chime in on that piece. How many miles on your 2012 TL? Something to think about-when I had my valves adjusted, my independent tech forgot to plug the motor-mount actuator solenoid back in and that was causing me to experience rough idle that I could definitely feel in the seats. This part is located on the firewall side of the engine. A long shot, but I figured I would mention it.
Good luck!
Old Mar 26, 2025 | 10:08 AM
altair47's Avatar
Engine mounts can cause rough idle if it is completely torn and the engine is sucking in excess air through it. My mounts have been seaping oil for several years now, the engine sometimes vibrates a little, but this does not affect idle(my mileage is 193к). Maybe you have a damaged vacuum line somewhere and the engine is sucking in air or just a crack in the air duct? But in your video the engine really works like a clock.
TL|GTX
Feb 23, 2022 09:08 AM
unity
1G TSX Problems & Fixes
Jul 13, 2009 09:10 PM
JP2
14
Mar 24, 2007 11:57 AM
