cruise control will not set and lights wont turn on
My cruise control was working perfectly fine earlier in the day, but tonight when I tried to set it, I realized the lights that are usually on at night were all on but the lights on all the cruise control and the up and down and ok/reset buttons lights were all off on my right side of my steering wheel and i couldn't set the speed no matter what but the light when i turned cruise control on (the cruise control main)_still came up on my dashboard. I don't wanna go to the dealer without knowing what exactly I can troubleshoot at home. Does anybody know what I can do?
Edit: forgot to say that the car wont beep when i double click the lock button either, and it was just doing it earlier in the day
Cruise Control Combination Switch Test/Replacement
There are SRS components located in this area. Review the SRS component locations Locations, and the precautions and procedures Service & Repair, in the SRS before doing repairs or service.
1.Remove the steering wheel Steering Wheel removal.
2.Remove the steering wheel rear cover Steering Wheel removal.
3.Disconnect the cable real subharness connector (A), then remove the steering wheel trim/cruise control combination switch (B).
4.Check for continuity between the terminals in each cruise control combination switch position according to the table:
-If there is continuity, and it matches the table, but the cruise control combination switch failure occurred on the cruise control input test, check and repair the wire harness on the switch circuit.
-If there is no continuity in one or both positions, replace the steering wheel trim/cruise control combination switch.
5.Install the cruise control combination switch in the reverse order of removal.
nishant11
2G CL Problems & Fixes
Mar 20, 2019 09:25 PM
