Is this a common problem?
Old Jul 27, 2017 | 10:59 AM
calvet's Avatar
What is causing my VSA and ABS Dash light to come on. for instance when I turn on the wipers it comes on. then shuts off after I turn the car off. seems like a intermitten problem to me.
Old Jul 27, 2017 | 11:52 AM
JM2010 SH-AWD's Avatar
Multiple warnings like this when the car seems otherwise OK is usually a symptom of a bad or failing battery. If the battery is older, have it checked and/or replaced.
Old Jul 27, 2017 | 12:30 PM
Old Jul 27, 2017 | 12:39 PM
losiglow's Avatar
Yep yep. Could be something else but it's highly unlikely that both your VSA and ABS are simultaneously having problems. I had a similar problem when my battery cable was loose. Since I cleaned and tightened it, I haven't had the problem. The TL's electronics seem to be very sensitive to voltage changes.
srg818
3G TL Photograph Gallery
21
Dec 10, 2016 09:00 PM
iforyou
Oct 25, 2016 11:50 AM
MussMan
Oct 18, 2016 12:32 PM
Anicra
4G TL Problems & Fixes
Oct 6, 2016 01:44 PM
soopa
Oct 25, 2001 06:48 AM
