Coin Tray Removal
Old Jul 21, 2011 | 11:24 PM
KB1Spec's Avatar
Coin Tray Removal
I'm trying to run a module inside my coin tray at the center console. I like to know if there's a diagram where I can remove the bezel trims running along the both side. Hope someone can help me out.
Old Jul 22, 2011 | 07:19 AM
TinyRK's Avatar
Autofahrer
Is that the thing which says "This is not an ashtray?"
Old Jul 22, 2011 | 07:59 AM
Stew4HD's Avatar
That's my badge holder! Coins? What are those things?
If that trim is like the 3G, you need a trim tool or putty knife with tape on the blade to protect the parts.. start at the rear most section and pry the trim up gently but with a bit of force to pop the trim out, working your way slowly towards the dash.
Old Jul 22, 2011 | 08:23 AM
Pseudomaniac's Avatar
And don't do it in the winter.
Get that cabin up to a nice 90 degrees or so, and you'll find things much more forgiving. If you have to put more than finger/wrist force behind it, you're in the wrong place; and those little clips will snap pretty easily, leaving you with pop and creak noises galore after reassembly. I usually throw a little wd40 or a dab of vaseline on the tension joints when I have that stuff apart to keep the noise factor down.
Old Jul 22, 2011 | 11:04 AM
KB1Spec's Avatar
Yes I like to take that out and run the wire inside through the coin tray. Wondering if there is a diagram for that. Thanks
Old Jul 22, 2011 | 11:06 AM
KB1Spec's Avatar
So I guess start from the shifter section and work my way up to the dash right?
Old Jul 22, 2011 | 11:07 AM
KB1Spec's Avatar
Cool...since its been kind of hot these few days I will leave my car outside then start working on it.
THanks
Old Jul 22, 2011 | 11:18 AM
Mr.Skytech's Avatar
Back at it with the TL SH
I am so lost on this one.
So you want to remove the soft thing to put a coin tray there?
Is it from acura this coin tray?
my 3G had a stock mount location for a coin tray. It housed my quarters, dimes and nickles.
Old Jul 22, 2011 | 11:30 AM
KB1Spec's Avatar
The coin tray is between the shifter and the control knobs in the center console. I'm trying to run my Tein EDFC module inside the coin tray. Right now my EDFC module is hanging with velcro under my steering column. I saw a simple diagram that there is a screw right beneath the vertical bezel trim. So I'm trying to see how easy or hard to take out the bezel trim so I can get into the screw from the coin tray.
Old Jul 22, 2011 | 12:20 PM
Mr.Skytech's Avatar
Ohhh ok cool.
Old Jul 22, 2011 | 01:32 PM
ib_jimmy's Avatar
look like you might have to take the center console off first.
Old Jul 22, 2011 | 05:24 PM
KB1Spec's Avatar
Ya I saw that diagram as well. I dunno where to start. I assume take off the side bezel trim then take the center console....
mlody
Dec 4, 2019 02:11 PM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
dainmezron
Oct 16, 2015 06:56 PM
ROWDY621
Sep 30, 2015 03:20 PM
