Coin Tray Removal
Autofahrer
Is that the thing which says "This is not an ashtray?"
That's my badge holder! Coins? What are those things? ![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
If that trim is like the 3G, you need a trim tool or putty knife with tape on the blade to protect the parts.. start at the rear most section and pry the trim up gently but with a bit of force to pop the trim out, working your way slowly towards the dash.
And don't do it in the winter. ![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
Get that cabin up to a nice 90 degrees or so, and you'll find things much more forgiving. If you have to put more than finger/wrist force behind it, you're in the wrong place; and those little clips will snap pretty easily, leaving you with pop and creak noises galore after reassembly. I usually throw a little wd40 or a dab of vaseline on the tension joints when I have that stuff apart to keep the noise factor down.
So I guess start from the shifter section and work my way up to the dash right?
Cool...since its been kind of hot these few days I will leave my car outside then start working on it.
THanks
THanks
The coin tray is between the shifter and the control knobs in the center console. I'm trying to run my Tein EDFC module inside the coin tray. Right now my EDFC module is hanging with velcro under my steering column. I saw a simple diagram that there is a screw right beneath the vertical bezel trim. So I'm trying to see how easy or hard to take out the bezel trim so I can get into the screw from the coin tray.
Pseudomaniac (07-22-2011)
mlody
12-04-2019 02:11 PM
dainmezron
10-16-2015 06:56 PM
09-25-2015 06:14 PM
