CHECK STARTING SYSTEM on a 2012 TL with a brand new battery
Old Aug 6, 2021 | 12:35 PM
CountChocula's Avatar
12 TL AWD 6MT 120k
Battery is 2 weeks old and fully charged
Was working fine now getting the error.
If I hold the starter down for an extra second it starts up fine.
Where should I start?
Old Aug 6, 2021 | 12:37 PM
check battery cables to see if they are corroded. check all grounds for corrosion.
Old Aug 6, 2021 | 10:00 PM
Thanks there was what looked to be an aftermarket positive terminal and it didn't quite fit to the bottom of the post.
Was super tight and no corrosion but I may try to order a new terminal to start with.
What other reasons would That warning come on for? Starter going bad?
Thanks!
Old Aug 6, 2021 | 10:01 PM
yes, if the error says check starting system...could be the starter
could also be the alternator.
i would be inclined to check more of the battery cables and grounding cables first tho
Old Sep 2, 2024 | 11:27 PM
Derekw_FL's Avatar
I just start getting this issue too. A month old battery as well. How did you end up solving it?
Old Sep 3, 2024 | 01:17 AM
check your alternator
Old Sep 10, 2024 | 06:49 AM
echodigital's Avatar
From TL to RDX
You can use multimeter to check it.
georgebizpro
Aug 12, 2020 09:07 PM
Acurate_
Jun 25, 2019 10:49 PM
ub_2k
2G TSX Problems & Fixes
Oct 17, 2011 09:22 PM
peters_sweet_CL
Sep 2, 2009 08:16 PM
bhusraoj
1G TL Problems & Fixes
Aug 6, 2009 01:56 PM
