Check DRL System
Old Jan 6, 2020 | 01:55 AM
ti al's Avatar
7th Gear
Check DRL System
Hi guys. Lately i was on the road with the high beam on and suddenly they shutted off. So when i arrived at home i closed the light cause they were on « auto » and then « check Drl ststem » went on
The 3 fuses are fine. And my fog light closes when i put the high beam on like normally
does the second bulb close if first one blow ?
or if its a bulb problem only one will shut and the other will light up
cause atm both hi/lo/drl doesnt work and stopped at the same time
oh and maybe someone have the lightning diagram from the fuse box to the light
and. How can i check if theyre is current in the light connecter. With a multimeter ???
thank you for your help 👍🏼
psteng19
1G TSX Problems & Fixes
Sep 8, 2019 12:23 PM
wmahmud
4G TL Problems & Fixes
41
Jan 3, 2017 11:12 AM
rotciveel
2G TSX Problems & Fixes
Apr 8, 2013 07:25 PM
helraiser
May 26, 2008 10:35 PM
larryka
Feb 7, 2005 12:46 AM
