Car Wouldn't Start
Old Sep 17, 2012 | 12:58 PM
ShadeTreeMech's Avatar
Car Wouldn't Start
I had a bit of frustation with the TL yesterday so I thought you guys could get a laugh at my expense. My wife and I were getting back into the car after church yesterday and when I hit the start buttom nothing happened. The radio and accesories would turn on but the engine didn't even try to crank. I tried again making sure the brake pedal was pressed and still nothing. I then though perhaps the signal from the remote wasn't strong enough so I the remote in the slot. Tried a couple more times and still no success. I tried to pull the key out and it was stuck for some reason. Then I looked down at the shifter (AT) and realized saw that it was in drive. I had forgotten to shift to park when I turned the car off earlier that morning. The key wasn't in the slot then so I had no indication that the car was still in drive. Man I felt like an idiot.
Has anyone else had a brain fart and done something stupid like this?
Old Sep 17, 2012 | 01:05 PM
potmilkz's Avatar
ive done it a few times,, but i have never left the car with it being on drive..
i did however parked, got out of the car to grab something and got back into the car, tried to start it and pretty much figured out that it was on Neutral the whole time.. i spent like 3 mins trying to figure out what went wrong..
but next time, just remember to HEAR your car locking.. thats the only indication that everything is fine.
Old Sep 17, 2012 | 01:41 PM
LawnPro's Avatar
Scott
These cars have so much TECH built into them - its probably happened to everyone.
Everything has to be just right to start, maybe for security purposes.
Old Sep 17, 2012 | 01:57 PM
potmilkz's Avatar
but his car should have beeped if you left it in drive and walked out of the car.. i know mine does.. but it only beeps if you are about 5+ fee away, if your in the trunk doing something then it wont beep.
Old Sep 17, 2012 | 02:17 PM
LawnPro's Avatar
Scott
Yeah that's a good point pot, should of beeped
Old Sep 17, 2012 | 02:54 PM
lji's Avatar
lji
Lucky that you didn't park it on a slight slope and the car could have started rolling after you left (I'm assuming you hadn't set the parking brake here). Guess God was looking out for you
http://blogs.insideline.com/roadtest...ing-brake.html
Old Sep 17, 2012 | 05:28 PM
billyt1963's Avatar
Actually you don't have to walk to far away. I have left the car in aux, closed the driver's door and then walked back to put gas in, and the car beeps.
Old Sep 17, 2012 | 06:19 PM
dwest1023's Avatar
That's nothing. The other day I park my car at work, put the cover on( I always cover my car) and forgot and left the motor running! It idled for 8 hrs. I still cannot figure how I did that one. I even dusted the car off before fitting the cover. My engine is super quite at idle I guess. Even after I closed the door I did not notice the beeping. When I entered the car to go home I notice the car interior extremely hot. Then I noticed my diplay saying, " no usb connection". I was like, WTF, only THEN did I realize I left the engine running!
Old Sep 17, 2012 | 06:58 PM
potmilkz's Avatar
thats car abuse.. you should be reported to the authorities..
Old Sep 17, 2012 | 09:27 PM
It was a flat parking lot so I didn't set the parking brake. I don't recall hearing a beep but this car tends to beep a lot so I probably disregarded it. I will listen better next time.
Old Sep 17, 2012 | 09:43 PM
Tech12's Avatar
Not an Acura story. But I had driven my wife's Isuzu Rodeo a few years back and came home and pulled into the garage. That style SUV had a separate glass window in the back and the rear trunk door could be opened separately. I opened up the window, opened up the swinging rear door and took at the groceries. I then pushed down the glass door and closed the trunk door. Oops wrong sequence! I smashed the entire rear window with the door and glass shattered and went everywhere. I was finding glass pieces for a year in that car! Worst part is the the wife has never let me forget it.
Love the site guys, by the way.
Old Sep 17, 2012 | 09:52 PM
Years ago my wife left her car running all day while at work. Great way to burn through a tank of gas.
peti1212
ILX
22
Jan 5, 2022 05:14 PM
Feb 25, 2020 09:57 AM
jordanboi
Sep 5, 2015 01:33 AM
NSolace
Sep 3, 2015 08:02 PM
dlknight
Sep 3, 2015 07:54 PM
