Car not Starting
Old Mar 30, 2022 | 03:01 PM
Thxu4thehelp's Avatar
4th Gear
Car not Starting
My car is randomly not turning on. I step on the brake hit the start / stop button and nothing happens. Dash board lights and head lights turn on. We have checked all fuses and relays. Mechanic was able to turn over the engine by giving the starter direct power. We have connected the scanner and it’s not able to read (note we have used this scanner in the past no problem). I have a video but it’s to large to post here I will try to upload and make smaller. Any suggestions is appreciated!
Old Mar 30, 2022 | 03:04 PM
4th Gear
Forgot to mention 2009 Acura TL with keyless access system.
Old Mar 30, 2022 | 06:09 PM
csmeance's Avatar
Start by checking fuses and go from there.
Old Mar 31, 2022 | 02:25 PM
4th Gear
We have checked them all under the hood inside the car and they are all fine.
Old Apr 7, 2022 | 06:34 PM
4th Gear
Found the Problem. The BCM went out so we had that replace. Key and engine computer had to be reprogrammed.
Old Apr 9, 2022 | 05:27 PM
nikakuchaidze's Avatar
Would you be willing to share more details regarding:
1. how you/the mechanic were able to diagnose this? and
2. how the reprogramming procedure was done? I suppose it was done at the dealer?
I think I'm having the same issue right now...
sirjordan186
Dec 17, 2015 12:51 PM
pmartone
Feb 19, 2015 08:32 AM
Brandonbebeast
Aug 30, 2013 06:28 PM
daiyi3
Jun 26, 2013 06:05 PM
Mach30SiR
1G CL Problems & Fixes
14
Oct 23, 2007 12:50 PM
