Brightness
Old Jan 1, 2015 | 07:30 PM
Westside_TL's Avatar
Brightness
My nav turns blk n white and the background on audio also dims, is this a battery problem? I have a redtop battery i installed 3 months ago
2011 acura tl tech pkg
Old Jan 1, 2015 | 09:35 PM
Ohio's Avatar
I really doubt that's a battery problem. Does the rest of the electrical behave normally?
Can you describe the problem a little more? When does this happen exactly?
Old Jan 2, 2015 | 03:00 PM
All the inside lights are dim and stay like that while the car running, the navi is in blk n white like its in safe mode same with audio
Old Jan 3, 2015 | 10:22 AM
Old Jan 4, 2015 | 01:51 PM
Tonyware's Avatar
'20 TLX SH-AWD A-Spec
Hold down the buttons at the same time: Menu - Map - Cancel for about 5 seconds. The "Select Diagnosis items" screen will appear. Go into the detail testing and find the menu for testing the screen. See what the test comes up with. A more detailed procedure must be in your owners manual for the Navi.
Old Jan 5, 2015 | 12:42 AM
Ohio's Avatar
It almost sounds like a big ground might be loose somewhere. If it were mine I would check the tightness of connections at all major points (battery, alt, chassis ground, etc)
BigDogues
Jan 18, 2022 11:35 AM
guitarplayer16
Nov 29, 2015 02:03 PM
12vancover
Oct 16, 2015 12:04 PM
Sep 25, 2015 06:05 PM
eastcoastguy
Sep 23, 2015 06:29 AM
