ABS Module went Kaput
Old Jun 20, 2022 | 10:44 AM
Dmass777's Avatar
Dealer wants $1,600 to change it. Can l buy one on Ebay for $300 and do it myself and do l need to bleed the breaks after!
Old Jun 20, 2022 | 03:57 PM
csmeance's Avatar
You will need a scan tool to do the neutral position reset for the VSA system, no programming needed really. You will have to bleed the brakes.
Old Jun 23, 2022 | 11:09 AM
dvd2012tl's Avatar
DMASS777, What were your symptoms to lead you to think your abs module is bad?
Old Aug 24, 2022 | 05:22 AM
Dmass777's Avatar
l had abs, vsa and check abs light come on. The are still on right now!
Old Aug 24, 2022 | 01:37 PM
Qwerty12's Avatar
Did you check your Wheel Sensors? My VSA and ABS lights are on and they said I need to replace right wheel sensor.
Old Aug 31, 2023 | 09:13 PM
DKSummut's Avatar
Can’t clear and dash lights
Writing in this thread bc our 2013 TL has the dash lit up with warning lights. Mechanic and then dealer couldn’t find anything wrong. Dealer called Acura National they suggested fixes that didn’t work. They say “likely “ bad VSA and replacement costs $1800, and they don’t know it will solve problem. My mechanic disconnected the VSA module to see if he could clear the dash errors. No luck. He admitted he doesn’t know much about VSA, but now that nothing cleared with VSA disconnected I’m not sure what to do. Don’t want to spend $1800 on something that might do nothing but the car is basically junk if not fixed. Hoping someone has experienced this.
Old Sep 7, 2023 | 10:25 AM
JM2010 SH-AWD's Avatar
Any chance your battery is bad or failing? A failing battery can light up the dash like that.
bhurlbut
Mar 14, 2009 01:30 PM
Chief F1 Fan
Mar 31, 2005 06:12 PM
shaolin
Dec 15, 2003 01:49 PM
VTEC
Nov 19, 2001 11:02 PM
