2012 TL SH-AWD Heater issues?
Old Apr 11, 2012 | 08:49 PM
Powpow1's Avatar
Hello,
I have recently purchased a 2012 TL SH-AWD. I have noticed that when my temperature is set to 75 degrees that the air coming from the vents is still cool. It seems the max heat is 86 and the min cool is 58 so 72 would be the midpoint. If I crank the air up to 86 the car gets hot as expected. I would think that I should feel hot air from the mid point and higher.
The only reason I am posting is because my wifes Ford Fusion can be set to 74 degrees and hot air is blowing. Not the slightest hint of cool air.
Is this a problem?
Old Apr 11, 2012 | 11:48 PM
njsimons's Avatar
No its not a problem the car uses that outside temperature and determines what that 75 degrees in the car should be. For example if its 65 outside and you set the temperature to 75 the sensor determines whether it needs to blow cool or hot air to make the cabin 75 degrees.
Old Apr 12, 2012 | 08:50 PM
3rdGenHybrid's Avatar
The actual number you choose doesn't refer to an actual degree of temperature, more of a scale. Your climate control uses interior air temp exterior air temp and a sun load sensor that determines temperature, blower speed, and vent mode. Even with auto off, the middle won't be Luke warm, it's just not designed that way.
Old Mar 12, 2016 | 02:27 PM
Nsxpa's Avatar
3rd Gear
Thanks for the info njsimons and 3rdgenhybrid. I'll check it in my car and re-post. I just haven't experienced this "heating/cooling" issue before.
ssjkev16
Dec 22, 2024 02:51 AM
orkoTL
4G TL Problems & Fixes
107
Sep 28, 2017 09:12 AM
nash3222
Sep 10, 2015 09:46 PM
kuzdu
Sep 10, 2015 08:42 PM
