ATF Overfill
Old Mar 13, 2016 | 10:37 AM
tommh1024's Avatar
ATF Overfill
I'm currently doing a 3x3 flush with my 2012 TL 3.5. I drained 3.25 quarts and put back in only 3 quarts and when I do the normal atf check procedure(radiator fan on, ground level), the dipstick shows atf fluid past the max dot. Is it supposed to be like this?
Old Mar 14, 2016 | 02:03 PM
Flyinblyian's Avatar
Interesting. I've done this service many times on my base 2012 TL and many other Honda V6 trans and its always spot on the max dot when I refill with 3 quarts.
How far above the max dot are we talking about?
Old Mar 16, 2016 | 07:17 AM
JasonK's Avatar
09 TL SH AWD /w TECH
Did you drain the tranny fluid with the car hot? Your not supposed to do it while its cold. It wont hurt it to be a little bit above fill level. Did you go through all the gears and then check the level again?
Old Mar 16, 2016 | 09:49 PM
Reorge's Avatar
Hmmm. Mine take exactly 4 qts to reach the max fill using the service manual procedure.
t3hhcaptain
2G TSX Performance Parts & Modifications
30
Feb 27, 2018 12:20 AM
crazym0nkey
Feb 29, 2016 01:12 PM
Freddyceemore
Feb 26, 2016 12:26 PM
cbernard
Feb 12, 2016 04:52 PM
