13 TL SHAWD charging system issues
Old Jul 15, 2023 | 04:00 PM
Atanas Dimitrov's Avatar
guysI'm having issue w my charging system. Last night while driving msg check charging system came on. Got home. Check battery . Only 10.2v. Hooked battery to tender over night. Batt is 12.9v and its brand new battery. 3/23.start car checked amp draw at alternator nothing. Checked voltage at battery nothing. I just replaced the alternator 2 months ago for same reason. Took it back to autozone installed new alternator. Now chargingBatt voltage 14.1v with AC on.The badTurn off acc and voltage drops to 12.5v and back up to 13.9v for 5 sec while driving. And keeps doing it.​​​​​​1turn AC on. Stays solid 14.1vwhat is going on?
Old Jul 18, 2023 | 04:07 AM
dwest1023's Avatar
I have read, if you did not buy Oem alternator you will have issues
Old Jul 18, 2023 | 09:06 PM
Ok. But why? What's the difference?
Old Jul 18, 2023 | 09:11 PM
https://www.partsgeek.com/catalog/20...lternator.html
will this work? It's a Denso reman.
Old Jul 18, 2023 | 10:11 PM
altair47's Avatar
As far as I know, these are the modes of a smart charging system, with a small load, the alternator works to support the battery voltage, and not to charge.
Old Jul 19, 2023 | 04:22 AM
dwest1023's Avatar
im not sure, but if you do a search u will find others with similar issues. There must be some circuitry in Oem that aftermarket don’t have. If mine goes out Oem is going in. I’ve seen too many charging issues with non Oem. Do the search and u will see
Jmeyer152
1G RDX Problems & Fixes
Mar 23, 2019 05:33 PM
imdinky
Jun 7, 2018 02:17 AM
Courtney Lopez
14
Nov 3, 2012 12:24 AM
Tory
1G CL Problems & Fixes
Jan 6, 2011 09:35 PM
RuthlessPastor
Apr 6, 2009 09:57 PM
