charging system
Old Jan 2, 2011 | 08:44 PM
Tory's Avatar
charging system
how do you check if the charging system is providing to much power to the battery therefor cause corrosion on the battery terminals?
Do you use a multimeter to the battery? or where would u find out how.
Old Jan 4, 2011 | 09:05 PM
JamesB1985's Avatar
I dont think over charge would cause corrosion on the battery terminals? maybe im wrong? But i dont think so. A great way to check the charging system is to turn all your accesories/ heat/ defoggers on, then go to your battery and put your DVOM red lead on positive post and your black lead on the negative post. If your getting 12 Volts out of your battery with all Acc.s on, you know you have a good alternator.
Old Jan 6, 2011 | 09:18 AM
P0401's Avatar
I use one of these http://www.iequus.com/Product/Detail...E-91FE755F3483
Old Jan 6, 2011 | 09:27 AM
P0401's Avatar
I copied the wrong address, I got mine from amazon for less than that page shows. here is the amazon page http://www.amazon.com/Equus-3721-Bat.../dp/B000EVWDU0
Old Jan 6, 2011 | 09:35 PM
JamesB1985's Avatar
That thing looks excellent
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
navtool.com
Sep 25, 2015 05:15 PM
Cgannotti
Sep 25, 2015 05:04 PM
