How to turn off the VSA ?
Old Dec 8, 2010 | 09:23 PM
Momyc's Avatar
2015 TLX SH-AWD Elite BWP
Question How to turn off the VSA ?
Maybe it sounds stupid ,but these days when we got first snow storm I realised that I cannot turn off the VSA.
I read the manual where is saying to push and hold the VSA OFF button up to hear a beep. I did it and no beep and no VSA OFF light on the dash.
I'm wondering if is something wrong . The VSA itself seems to work fine when I tried some slides on the snow.
Is the fact that I installed the winter wheels without pressure sensors affecting the VSA functionality ?
Thx.
Old Dec 8, 2010 | 10:34 PM
tharbemiko's Avatar
Yeah to turn off VSA you just have to hold the button until you hear a beep. After that you'll see the orange VSA icon (a car with swerve marks behind it) and this indicates that it's off. I'm not 100% sure about winter wheels affecting VSA functionality, but I do remember reading a thread somewhere about certain tires affecting whether you can turn off VSA. Hope that helps.
Old Dec 9, 2010 | 08:32 AM
Momyc's Avatar
Thanks. I tried that but no luck . I press the button and hold it for more than 10 sec and no luck. Probably because I have the warning from TPMS system it may disable the ability to turn off the VSA !?
Old Dec 9, 2010 | 11:06 AM
tharbemiko's Avatar
Oh yeah if you're getting a TPMS warning then that's most likely what's causing the problem. I haven't experienced this myself but I DEFINITELY remember reading the about the same exact issue. If you put your stock tires back on, then you SHOULD be able to turn off VSA (if you have spare time you can try this to verify that nothing is actually "wrong").
Old Dec 9, 2010 | 06:02 PM
jspagna1's Avatar
The Sicilian
Yes it's happening because of the winter tires. My car does the same thing. The TPMS is on so I just hit the reset button to get rid of it, but the little tire icon stays on because I did not get the tire the TP monitors when I got the snows.
The VSA will work when you put your summer tires back on. No worries.
Old Dec 9, 2010 | 06:48 PM
Momyc's Avatar
Thanks guys !
Old Jul 19, 2023 | 09:24 AM
ProAc_Fan's Avatar
6th Gear
Sorry to dig up a very old thread but I'm experiencing issues with the VSA on my 2007 Acura TL. Intermittently the VSA will activate and car will have no power to accelerate. This can obviously be a little dangerous depending on traffic conditions. Holding down the VSA button puts an orange triangle with an exclamation point on the dash cluster but it doesn't disable the VSA because it can still kick in. Can I unplug that VSA module and "fix" this problem? Is there a cheap solution to this issue? Car is old now with over 300K km on it so dumping lots of money into it isn't a wise move.
Old Jul 20, 2023 | 03:15 PM
echodigital's Avatar
From TL to RDX
@proac_fan I would post in 3G forum because your TL is from 2007.
Old Jul 20, 2023 | 08:05 PM
ProAc_Fan's Avatar
6th Gear
Ok great thanks for the heads-up
mada51589
Jan 9, 2025 04:40 PM
SidhuSaaB
May 30, 2020 12:40 AM
navtool.com
31
Nov 16, 2015 08:30 PM
LeVeL
Sep 21, 2015 06:57 PM
