09 TL tranny issue
Old Dec 24, 2014 | 04:11 PM
oreo615's Avatar
09 TL tranny issue
Just tonight my tranny slipped and the rpm's spiked when I pulled out slow and it shifted between 1 and 2.I've read about Torque converter problems with the TL'S.I bought the car 4 weeks ago with 62k miles.Are there any extended warranties on these problems?
Old Dec 25, 2014 | 01:38 PM
csmeance's Avatar
most extended warranties don't cover pre-existing conditions and have a 1000 mile clause before you can file a claim.
Are you sure the transmission is slipping? 62K is not that many miles and you are 2K outside the 60K powertrain warranty. Perhaps acura might pick up some of the cost of it.
Old Dec 26, 2014 | 06:41 PM
oreo615's Avatar
Tranny has been shifting fine ..just seems to have a very aggressive up shift and down shift...
Old Dec 28, 2014 | 08:14 PM
real_mckoy's Avatar
you have 7 years or 70,000 miles powertrain warranty whichever comes first. some powertrain parts have even more coverage under warranty but let me not quote the booklet if you read the manual you can get even more details..
When was the last time or have you ever changed the transmission fluid? Has the transmission fluid ever been changed on that car?..
Honda is know to have transmission problem i.e shift solenoid issues, slips in changing and so forth. You can feel the difference when the transmission fluid has been changed it shifts smoother. Maybe you should look into getting the fluid changed first.
Here is a link to the booklet just follow the prompts
Owner's Manual & Warranty | Acura | Acura Owners Site
Old Dec 31, 2014 | 10:06 AM
BSG1's Avatar
The torque converter warranty was extended to 8yrs/105k miles.
Old Jan 1, 2015 | 10:47 AM
Tonyware's Avatar
'20 TLX SH-AWD A-Spec
A tranny oil change can do magic most of the times. However if you haven't done one according to the schedule then it may be complicated. However, let the car warm up a bit, especially in cold weather, before you put it into gear and start shifting. Yes, at freezing cold temps the tranny shifts and gives you a kick in the neck!
Old Jan 2, 2015 | 12:57 PM
oreo615's Avatar
Yes ..It has been cold here in Pennsylvania, and my 01CL that I traded used to shift like that in cold weather...Also,my Honda Accord does it.
Old Jan 4, 2015 | 10:38 PM
shawd_dy's Avatar
8th Gear
If you have a torque converter problem you should feel shuddering, not sure if you have experienced that..
Yikes
May 3, 2021 04:29 PM
mugen_kid
Nov 13, 2015 10:38 PM
Junior Noboa
Sep 21, 2015 06:28 PM
JDMVP
1G TL (1996-1998)
Sep 17, 2015 06:14 PM
kuzdu
Sep 10, 2015 08:42 PM
