'09 TL -- broken ECU! Repair costs?
Hey, just yesterday I purchased an 09 TL. Delivery was at 6:30 and I was nearly home at 7:30. However, before I went home, I decided to stop by my local church for a minute. Then for a few circumstances, I had to wait in the car for a few minutes. So while waiting, I thought it would be time to setup my Bluetooth hands free link. During this, the car was on, but the ignition wasn't; in the ON (II) position. So I waited for a few minutes, approximately 7-10. Then I had done what I had needed and was time for us to leave.
So I try turning on the car, no reaction from the engine. It starts flashing in the dash when I try running the engine. Finally, I tried all sorts of things, and no good luck.
Then, someone passing by offered a boost and I said sure. So he got everything set up and began the process. But as much as he tried no luck.
HOWEVER, speaking to my friend later, he asked me a few questions. TURNS OUT, booster cables weren't connected properly!! And this messed up the ECU. I had to park the car at the church, by pushing it into a parking spot, and the dealer is coming to tow it to his shop today.
Is it really the ECU, how much is it gonna cost!?!
06 Anthracite TL
It's impossible to tell if it's the ECU just from what you said, but unfortunately, it is a possibility. It could be just a dead battery as well. Let the dealership advise you. You could always just swap in a battery and see if that allows the car to start and run before the dealer has it in their possession. Did you get the car with a warranty?
Your ECU is NOT Bad. You cannot hurt the ecu by connecting the battery cables wrong. What you have is a dead battery from leaving the ignition on without running the engine. It possible that you took out the main fuse to the car. Don't have my service manual so, Im not sure what fuse you should check.
06 Anthracite TL
^^ Actually, very good points- I'd go the new battery route (or charge your existing one) at least to try before bringing the car to the dealer- they might try to upsell you on a bunch of new components you likely won't need.
^^ LMAO!! I know....What is this world coming to?!
Fortunately for us, the engineers have put enough idiot-proof mechanisms to prevent the ECU from going bad. Most likely, if the booster cables where - to + and + to - then the main relay (PGM-FI) is burned or even before that the fuse that protects the main relay is burned. Doing a load test on the battery is also a good idea, since those 09's ones won't last more than 3-4 years.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
