Rotors?
Old Feb 15, 2011 | 07:10 AM
Richs09TL's Avatar
Bigrich1974
Rotors?
Anyone running crossed drilled and slotted rotors? If so what brand and where can I get? I think they would look sweet.
Old Feb 15, 2011 | 07:22 AM
you dont mention if you have the base model or the 3.7...
Excelerate Performance carries slotted and drilled rotors for the 3.7.
Now, I'm unfamiliar with your years, and dont know if the 3.7 uses a larger rotor.
http://store.excelerateperformance.c...s/c-10043.aspx
Old Feb 15, 2011 | 08:32 AM
Richs09TL's Avatar
Bigrich1974
Sorry! I have the 09 tech sh-awd 3.7
Old Feb 15, 2011 | 10:28 AM
Bearcat94's Avatar
AZ Community Team
You can look up rotor sizes here: http://www.hondanews.com/channels/ac...tions/releases
3.5L and 3.7L trims all have the same size rotots, front and rear.
FWIW, I've read that if you want drilled/slotted to make sure you buy from a manufacturer that DESIGNS the rotor to be drilled and slotted. Apparently some re-sellers, buy blanks and then drill them which may lead to cracking at the holes. IOW - beware of fly-by-night, cheap ebay sellers. Buy from a reputable dealer/manufacturer.
Old Feb 15, 2011 | 10:40 AM
Pete2010's Avatar
Personally, I would get slotted rotors, I've heard that drilled rotors tend to crack (or at least low quality drilled).
Old Feb 15, 2011 | 10:42 AM
Excelerate's Avatar
Former Sponsor
We have a few sets of ROTORA slotted or drilled and slotted rotors in stock for the front of the 09+ TL. Whether AWD or FWD the rotor and pad are the same for the F&R.
http://store.excelerateperformance.c.../i-279094.aspx
http://store.excelerateperformance.c.../i-279095.aspx
We also have ceramic pads for the front and rear if needed. Use promo code AZROTORA for a discount on the rotors.
Old Feb 15, 2011 | 11:21 AM
potmilkz's Avatar
ouch, pricy per rotor..
Old Feb 15, 2011 | 12:03 PM
Pete2010's Avatar
Got to pay to play.
Old Feb 15, 2011 | 12:42 PM
Flipster23's Avatar
Drilled Slotted I hate I have them actually about to get rid of them..If I were u I would just go slotted
Old Feb 15, 2011 | 03:43 PM
Six Shifter's Avatar
an adult perspective
When I get ready to replace the stock rotors, I'm going to check into DBAs first. Had Rotoras on my CL, and after less than 5000 miles went back to my oems which had over 50 k on them. Tried the cyberfrozen units also, and were better than the Rotoras, but still had problems. Switched to DBAs, and was problem free. Not knocking any vendor who pushes any particular brand ... just my experience with the brand.
Old Feb 15, 2011 | 03:52 PM
Bearcat94's Avatar
AZ Community Team
Drilled Slotted I hate I have them actually about to get rid of them.. ....
Why? What brand?
Old Feb 15, 2011 | 03:56 PM
Flipster23's Avatar
Originally Posted by Bearcat94
Why? What brand?
I've had some no name ones (thats why) and then IIRC rotora where the other ones that I had for a brief second warpage was a big problem on both..
Old Feb 15, 2011 | 05:32 PM
Teddybear's Avatar
Subsonic
quoted for truth.
this is what happened to my friend's rear crossdrilled+slotted rotor.
i'd only go slotted.
Old Feb 15, 2011 | 05:34 PM
Flipster23's Avatar
^ damn yup I heard of that happening too
Old Feb 15, 2011 | 05:50 PM
Teddybear's Avatar
Subsonic
you should've heard the noise it was making!! like a freakin banshee
Old Feb 16, 2011 | 09:34 AM
Excelerate's Avatar
Former Sponsor
Well if the company does the process correctly the rotor should be fine. We have actually moved primarily over to STOPTECH/Powerslot rotors but we used to sell a lot of ROTORA rotors and have had good experiences 99% of the time.
Old Feb 16, 2011 | 09:50 AM
user 0579729724's Avatar
09 Accord Coupe 6 Speed
I replaced all 4 corners on my 09 Accord Coupe with EBC Gold Sports. They're slotted and dimpled, rather than drilled, to avoid cracking. I've had them for several months and I'm happy with them.
Old Feb 16, 2011 | 06:37 PM
jnc2000's Avatar
RacingBrake has rotors for the 4G
Old Apr 8, 2011 | 08:23 AM
mel88hrman's Avatar
6th Gear
I have my OEM rotors resurfaced at less than 15,000 miles. I thought this was excessive. I just had the front rotors replaced under warranty. What is the difference in rotors? I have a 2009 TL Tech.
Old Apr 20, 2011 | 12:41 PM
Kingmeow's Avatar
That's weird. My '09 AWD non-Tech has 30k miles on the original rotors and they look fine. Why were yours resurfaced at 15k miles?
Old Apr 20, 2011 | 01:59 PM
GoosedTL's Avatar
Proud owner of a GoosedTL
I honestly think my stock rotor are warped because heavy to moderate braking makes strong vibrations. Can I replace them under my warranty?
I am one those guys who knows little about warranties in this case.
Jul 16, 2017 07:33 AM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
lanechanger
Oct 13, 2015 10:56 AM
08_UA7_Gr33k
Sep 27, 2015 01:56 PM
