Light weight crank pulley
Old Jan 17, 2012 | 08:24 PM
3rdGenHybrid's Avatar
So ive searched the forum but keep getting results for 3rd gen tl and cls, I was just wondering if anyone has done this to a 4th gen tl and what results have they got??
Old Jan 18, 2012 | 07:03 AM
HeartTLs's Avatar
Jnc2000 has, I believe Puesdo will be shortly and I'll be ordering/installing mine within the next 2-3 weeks.
Old Jan 18, 2012 | 07:52 AM
Pseudomaniac's Avatar
I'm on the fence. I did this on my CL-S6M at the same time I did a light fly/clutch, and the outcome was not good. Clutch engagement was very tricky, and burned up a clutchmasters street disc in 10k of just daily driving.
The 3G guys concensus was to do the light fly, or the pulley, but not both.
I remember reading here earlier that there aren't so many pulley options on the 4G because the pulleys are lighter than they have traditionally been.
On the Civics/Teggys I worked on, the pulleys were good for adding a little pep in the step; it's not like some huge, noticeable, neck snapping power adder, but you notice a bit more urgency getting through the revs.
At $100 - it's a consideration; at $250, I'm not sold on it.
Old Jan 18, 2012 | 07:53 AM
only first gear takes advantage of the pulley. ^
Old Jan 18, 2012 | 10:04 AM
Excelerate's Avatar
Former Sponsor
The lightweight crank pulley is a great mod. Some people says it's their favorite mod. You will notice better throttle response and an increase in hp/tq. The TSX 2.4 saw 10whp and 10 wtq with the lightweight pulley set.
And I've sold hundreds of these to the 3rd gen TL owners. I've sold dozens to 4th gen TL owners, and have received the same positive feedback.
Old Jan 18, 2012 | 07:32 PM
Well I had the UR lightweight under drive on my 05 tl and it made a huge difference, but on my 07 tl-s I didn't feel any difference, just didn't want the same results with the 4th gen..
Old Feb 11, 2012 | 12:23 PM
goodoldayz's Avatar
do these only work for manuals or does it apply to automatics as well ?
Old Feb 11, 2012 | 12:24 PM
Auto as well.
Old Feb 27, 2012 | 11:33 AM
goodoldayz's Avatar
what price should i be expecting for this ?
Old Feb 27, 2012 | 11:45 AM
I think last price they spit out was $250 or something crazy. At $100, I'd think about it. At $250 for a lightened/balanced pulley set - I'd think about it. $250 for the 4-5hp you might gain on the low end, is a bit steep. I'd have to see what the weight differences are between it and factory, and some dyno sheets to believe it really does anything more than that.
Old Feb 27, 2012 | 04:40 PM
AcctCanc01's Avatar
Cost?
Old Feb 27, 2012 | 07:58 PM
Excelerate's Avatar
Former Sponsor
Originally Posted by Altegris
Cost?
http://store.excelerateperformance.c.../i-236893.aspx
Old Feb 27, 2012 | 09:18 PM
goodoldayz's Avatar
any group buys on this any time soon ?
Old Feb 28, 2012 | 12:35 AM
alienstudio's Avatar
any member actually did a dyno with this crank pulley?
how many people had this mod done to their 4G?
Old Feb 28, 2012 | 03:40 PM
Excelerate's Avatar
Former Sponsor
We can set one up. If we get 10 people we can offer a 10% discount.
There have been CL/TL dynos. Here is one:
There was also an independent dyno done on a 1G TSX 2.4. The car made about 10 whp/wtq.
https://acurazine.com/forums/showthr...ht=pulley+dyno
We've sold and installed a number of these on the 4G TL. It frees up typically 7-10 HP on most J-series motors.
Old Feb 28, 2012 | 07:01 PM
Knew I'd find it if I did some digging.
The J35/J37 crank pulley diameter is the same from the 03 Accord to present it seems.
I'm recalling that the J37 FACTORY pulley is 3lbs lighter than the J35 FACTORY pulley on the 3G TL, but I am 99% sure they are all the same diameter (and the fitment guide on the XLR8 pulley backs this up).
Here's the Razco (which I had on both my CL-P and CL-6M) for $159, and I bet you can find it cheaper. This is a 3lb pulley, I'm uncertain the weight of the Unorthodox.
http://www.amazon.com/Ralco-RZ-914931-Underdrive-Pulleys/dp/B001VQJ9MM http://www.amazon.com/Ralco-RZ-914931-Underdrive-Pulleys/dp/B001VQJ9MM
Old Feb 28, 2012 | 08:28 PM
http://www.amazon.com/Ralco-RZ-91493.../dp/B001VQJ9MM
will this fit our TL?
Old Feb 28, 2012 | 09:32 PM
According to everything I have found online and cross referenced, the diameter and width are unchanged across the model years from 03 (and likely earlier) to present. All indications are that this should fit.
Old Feb 29, 2012 | 12:46 PM
I just ordred the 914930 for $111.90 shipped. I'll let you know if it fits, and how it compares to the stock. If it won't work on the 09, it's made for the 07 Type S, so I'll just throw it on my 07 instead.
Old Feb 29, 2012 | 01:14 PM
HeartTLs's Avatar
You linked product number 914931?
Old Feb 29, 2012 | 01:15 PM
EL19's Avatar
Dam that sucks! I just ordered this on ebay for $140 shipped. Wouldve been nice to save some cheddar
Old Feb 29, 2012 | 01:31 PM
I can't tell that there is much difference between the 31 and 30, but obviously the part numbers are different, so somethings up. I talked to Ray @ Ralco and he said if it doesn't work, that he'd make one for us. $200 per pulley, 15 order minimum, and $500 shared cost for making it. (Basically $233 a piece - prepay required)
Old Feb 29, 2012 | 09:51 PM
HeartTLs's Avatar
Isnt that the same cost as the XLR8 pulley; what would be the benefit of having a new one designed and manufactured? I'm also interested in the "slight" under drive pulley XLR8 advertises. Puesdo any opinions on under drive pulleys? XLR8 claims although it under drives, you can still use all your electronics?
Old Mar 1, 2012 | 05:44 AM
i'm not a big fan of the underdrives, but no, not sure about it.
Everything on that car is electric. The Navi, all the sensors, the power steering, etc. The last thing I want to do is underdrive my electrical system.
You really only "underdrive" it at idle with those, after you're in the revs - you're turning everything fast enough to generate accessory power.
Basically, it's putting smaller diameter pulleys on the accessories, to reduce resistance and improve throttle response. This comes at the expense of spinning them slower through the RPM range.
The lightweight ones reduce the drag in the same fashion, just lightening the load of the material being turned (and yes, lighter and smaller diameter would be a better load reducer than just lighter).
If the 914930 / 914931 crank pulleys work out - at MSRP of $139 - AND if they are much lighter than the stock, I'd say that's not a bad buy. I'm 99% sure the 3.7 TL pulley was already lightened by 3lbs over the prior gen, and that the accessory pulleys were also lightened in this fashion. I know the RALCO 914930 weighs 3lbs. The old J32 ones were quite heavy, like 20lbs if I remember properly. I don't know about the last J35 weights (or current ones).
Old Mar 1, 2012 | 01:51 PM
typeR's Avatar
stock pulleys on J32s and J35s were 8lbs my OBX ebay special was 2 lbs
Old Mar 1, 2012 | 02:37 PM
Got notice that I should be receiving the pulley tomorrow. I might even be able to get it on there this weekend, and the PCDs / J Pipe. We'll see...
Old Mar 1, 2012 | 02:43 PM
looking forward to the fitment result on the pulley
Old Mar 1, 2012 | 08:32 PM
HeartTLs's Avatar
Thanks Psuedo, keep us posted.
Old Apr 11, 2012 | 02:05 PM
TinyRK's Avatar
Autofahrer
Any updates?
Asking because of this: https://acurazine.com/forums/4g-tl-performance-parts-modifications-295/purdy-pics-xlr8-crank-pulley-weight-savings-853754/
Old Apr 11, 2012 | 03:13 PM
I've not fooled with it yet.
Old Apr 13, 2012 | 01:55 PM
The Ralco RZ 914930 is a smaller diameter than the J37 stock pulley.
From a rough measurement - the J37 pulley is 7 inches in diameter, and this one is at least an inch shy.
Old Apr 21, 2012 | 06:16 AM
FireNation23's Avatar
Every porn dvd in a
Just got an 09 FWD tech, wondering if you installed this yet. and is it easy to do yourself. Haven't looked around yet on this site, thanks
Old Apr 21, 2012 | 07:45 AM
Haven't yet, waiting for new resonators to come in, not sure why but the last pair I put in feel like its choking my exhaust, if you have a strong enough impact gun(I use a 3/4" gun at work), and a strong air compressor, you can do the pulley yourself(or use a breaker bar and a crank pulley holder tool, there's also the breaker bar vs the ground method, but I don't recommend that). Overall the install should take you 10mins max.
Old Apr 22, 2012 | 01:46 PM
Yeah - if you don't have an impact, I'd not recommend trying it.
Old Apr 24, 2012 | 02:54 PM
rockstar143's Avatar
I have a harbor freight 650 ft/lb dual hammer impact gun, i'm hoping it's up to the job. I may give this a try!
I'm a 3G but this seems like the most relevant thread on it these days. Keep us posted on your install and how you feel about it, please.
J.
Old Apr 26, 2012 | 10:08 PM
J.
The harbor freight 3/4 gun will work fine as long as the air supply is sufficeint enough. I use it on a daily basis lol
Old Apr 27, 2012 | 08:34 AM
it's a 1/2", but still torquey!
Thanks...tank is a 32 gallon, I think?!? It's the husky one on wheels...about 4 feet tall.
Old Apr 27, 2012 | 10:57 AM
Electric Impact > Air Impact any day.
Old Apr 27, 2012 | 11:14 AM
Well, I don't have one.
Actually, not true, I do have a lith ion one, but I doubt it'll do the job.
Old Apr 27, 2012 | 12:05 PM
Some of the battery ones aren't bad actually. I got tired of airhoses, and compressor noise, and waiting on tanks to fill and bought an electric 3/4 a couple years ago. It's craftsman, was only $80 and the thing is a workhorse. One cord - relatively lightweight, and all the torque you want without worrying about oiling .
