KTuner
Old Sep 14, 2020 | 12:24 PM
ARich's Avatar
9th Gear
KTuner
I just purchased a KTuner V2 and wanted to know if anyone knew what pre programed tunes it has and what they did
Old Sep 14, 2020 | 07:23 PM
csmeance's Avatar
the description should be listed in the tunes that show what mods they were meant for. What year and model of car?
Old Sep 14, 2020 | 07:26 PM
ARich's Avatar
9th Gear
its a 2014 acura tl.
Old Sep 14, 2020 | 08:08 PM
csmeance's Avatar
do you have any mods to the car? As far as I know there is a tune for an intake and also another tune for running without catalysts. The preset tunes get you pretty close, and you can use a company or person to do E-Tuning or in person tuning on a dyno for best results.
Old Sep 15, 2020 | 06:53 AM
ARich's Avatar
9th Gear
I have deleted both resonators and mufflers and added duel tips, cold air intake and a throttle body spacer. I am waiting for a jpipe and cat deletes
Old Sep 15, 2020 | 07:03 AM
LongLurkerTL12's Avatar
Gang Gang
Exhaust mods should always be first Can't rake in more air without letting more out. Ktuner for FWD has 1 base map, the SHAWD has 3 base maps. I believe intake is none of them. So need the exhaust mods. You should pull all the mods off that are not specific for the tunes and put them back on during a real tune from a professional.
Old Sep 16, 2020 | 04:40 PM
bigwavedave25's Avatar
Longtime Lurker
This is correct ^^^
Ktuner states in the software any modifications to the air intake will need a custom tune to make sure things are running properly. As to what the different available basemap tunes actually do, I am not sure what parameters each one adjusts... but I am also curious. It would be great to get a better understanding of the differences. Increasing levels of ignition/fuel, cam angle, duration...??
With that said, everyone's engine behaves a little different. I recently installed the 3.5" K&N intake on my 3.7 SH-AWD and the car loves it. LTFT's are reading better than before and there is a noticeable butt dyno feeling that the car is less choked for air (little better get up and go, IMO). Currently running the "Tune2" basemap from Ktuner with my supporting mods.
I believe Tunes 3&4 are for full exhaust including PCD's. But again this is for the 3.7L engines and I'm sure there are differences depending on if you have an Auto or Manual.
Old Sep 23, 2020 | 11:24 PM
OhhNoVtec's Avatar
Originally Posted by bigwavedave25
This is correct ^^^
i installed HFPC and Jpipe on my AWD 3.7. There isnt a tune for HFPC + Jpipe only so i picked the tune 3 HFPC + Jpipe + exhaust.
Old Sep 24, 2020 | 01:25 AM
Gang Gang
Changing the exhaust wo t do that much besides the mid muffler so it's okay to choose that one. I also suggest getting a new catback or atleast doing the mid muffler delete. That's my personal opinion for the health and long-term life of your engine.
Old Nov 7, 2020 | 09:49 PM
Catdaddy8686's Avatar
8th Gear
curious if you feel the increase in power. Thought about getting these same mods.
Old Nov 7, 2020 | 11:00 PM
OhhNoVtec's Avatar
My car feels a little zippier but I wouldnt say I see a big increase in power. It is kind of expected with bolt ons. I did notice a nice rumble on cold starts and a bit more rumble when stepping on the gas. I like it because car is only loud when putting petal to the metal. lol. Also i did notice an increase in gas milage. maybe 1-2 mile per gallon.
Old Mar 17, 2021 | 07:33 PM
Oceanminded3's Avatar
8th Gear
KTuner or Catback Exhaust
KTuner or Catback Exhaust, which one will have more of an impact on performance? I can only afford one right now and looking for some feedback
Old Mar 18, 2021 | 06:48 AM
Gang Gang
I would seriously do pre cat deletes or high flow pre cats and a J-pipe first. Those 2 things will release the power of your motor and allow it to breathe alot better.. the stock exhaust does not sound bad at all.. so those 2 things and you could easily mid muffler delete at a muffler shop for like $45 just to cut out the middle muffler and weld in a straight pipe while still having the 2 main end mufflers and it will sound so mean. High flow cats are expensive so if you go the route of the pre cat delete just replace the mid muffler with a nice resonator and you're golden. Then you can save up and put a nice cat back on later or ktune it.
Old Mar 18, 2021 | 08:03 AM
8th Gear
will the car still pass smog with the pre cat deletes? And how many pre cat deletes are there that I can replace?
Old Mar 18, 2021 | 09:06 AM
dopeboy1's Avatar
The inconvenient truth
Depends on the rules where you live... If there's stringent testing then no it won't pass and you can get high flow pre cats. PCD and hfpc come in pairs as there are 2 pre cats.
Old Sep 3, 2021 | 10:37 AM
4GJ37's Avatar
Do y'all know where I can find other tunes? Currently I am running ktuner basemap 4 and I want something more.
Old Sep 3, 2021 | 12:36 PM
^get a custom tune!
dyno tune it or have someone e-tune it over the internet
Old Sep 3, 2021 | 02:05 PM
Gang Gang
As he said above me. P2R can do E-tunes for you just send them a shout! And if you care about numbers later just hop on a dyno and see what it makes when you find convenience.
pplcrew
23
Oct 21, 2015 02:10 AM
Tumbleweed13
51
May 27, 2014 08:43 PM
defconskylude
Aug 4, 2011 03:42 PM
shychinoboy
Jun 19, 2006 06:22 PM
