Hissing sound coming from engine bay after installing P2R gaskets
Old 08-08-2010, 09:15 AM
YetiTL's Avatar
Hello,
I've recently installed the P2R Throttle body gaskets + spacers and the IMG gasket. Now when I push the gas pedal 1/3-1/4 of the way I hear a hissing sound coming from the engine bay. I didn't have that kind of noise when I only had the Takeda SRI.
Any thoughts on the reason? I tighten the clamps but all seems fine on that front...
I rolled teflon tape around the plug to ensure a tight fit as well.
Any input would be welcome and greatly appreciated.
Thanks,
YetiTL
Old 08-09-2010, 07:39 AM
CleanCL's Avatar
You need to check the bolts for the intake manifold.
Old 08-09-2010, 08:04 AM
prime81's Avatar
check for any loose vacuum hoses.
Old 08-09-2010, 09:40 AM
MyT6MT's Avatar
I have the hiss/wooshing sound with my Takeda intake when the throttle is open quickly. I still have not installed my TB spacer but I figured this is normal.
Old 08-10-2010, 11:31 AM
heathmallory's Avatar
I have the Takeda intake and P2P spacer installed. I notice a very easily heard "hiss" or "gasp" coming from the engine bay when I initially step on the throttle. Im guessing the removal of the airbox is why I can now hear the engine gasp for air as I step on it. Given what I'm reading here, must be normal.
Old 08-14-2010, 12:36 PM
YetiTL's Avatar
Well all the hoses are tight and I made sure everything was well bolted. It leaves the Intake manifold bolts and the TB bolts...
Old 08-07-2011, 12:17 PM
jiga21's Avatar
Hey so did you ever resolve the hissing problem man ? i got the same setup, 3.7 mani and tb with p2r gasket and spacer, and its a hissing noise also. It sounds like car is spooling boost with foot lightly on throttle
Old 08-07-2011, 11:54 PM
Pseudomaniac's Avatar
Torque wrench FTW.
02-25-2020 09:57 AM
james357
02-13-2016 02:37 PM
Tsov Tom
09-06-2015 07:56 AM
iRaw
ILX
09-05-2015 12:10 AM
obert
09-03-2015 08:40 PM
Quick Reply: Hissing sound coming from engine bay after installing P2R gaskets
